ISR break-in time?
Old 10-21-2004, 12:16 PM
Mikronized's Avatar
ISR break-in time?
Ok.. so I just finished the ISR mod last night... it seems to have more power EXCEPT when I'm on the freeway.. I can't hold speeds of 75 without going into overdrive... I checked all my connections and they seems tight. anybody have any ideas?
Also how long does it usually take the ECU to adjust for more airflow? is there a fuse I can just pull on the 2nd gen that will reset the ECU?
thanks
Old 10-22-2004, 03:01 PM
3.4v6's Avatar
did you reset the ecu? pull the neg cable off of the battery ... step on the brakes for 15 sec and reconnect.
Old 10-22-2004, 07:20 PM
kevin444's Avatar
or you can pull the efi 15AMP fuse in the fuse box. And just drive around.
Old 10-23-2004, 09:37 AM
3.4v6's Avatar
yea that too
Eggslinger
06-08-2019 03:32 PM
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
smiley52
07-11-2015 05:16 AM
Quick Reply: ISR break-in time?
