intermittent wiper swap - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-15-2004, 10:00 AM   #1 (permalink)
Send a message via Yahoo to hub_01_69
is it possible to do an intermittent wiper swap on the 2nd gen to do away with the annoying 2 speed setup...
thanks
hub
hub_01_69 is offline
Old 02-15-2004, 02:32 PM   #2 (permalink)
Quote:
thanks
hub
Can't speak to your particular application, but I did exactly that with my 01 Tacoma.
You will need to consult a parts book for your vehicle. Should be two different wiper control modules. In my particular case, the module for the "tilt steering" was the one that gave intermittent wiper control.
Only took about 15 minutes to make the change. Three screws on the cover, two screws on the module itself. Unplug the 2 speed, plug in the intermittent, replace screws and you're done.
Talk to your parts guy... Most likely it can be done for you the same way.
Edited to add:
The wiper control module should run you just a little over $100.
platform389 is offline
Old 02-15-2004, 03:03 PM   #3 (permalink)
might be on to somthing here...mine doesn't have tilt wheel..so maybe my yr (91) with tilt wheel will have the getup i need...can anyone confirm this?
Old 02-15-2004, 03:09 PM   #4 (permalink)
Arnold's Avatar
I cut/pasted this from the 4x4wire board,
"I did this on my '89. On at least the '89 and later trucks, they are prewired for it. All you have to do is swap out wiper switches. Cheezie really, that Toyota wouldn't include this as a standard feature on all it's trucks since it's so simple. But anyway, the only difference between the non-intermittent '89 and later switch and the intermittent switch is that a special relay is included in the switch mechanism. The 4Runner switch is different, but it will fit in the trucks. You'll just have an extra switch position for the rear window that you don't need. The switch only comes with vehicles with tilt wheel, so when going to your local junk yard, ask for a wiper switch from a SR5 truck or 4Runner with tilt-wheel. Then just bolt it in. "
__________________
My Photo Albums
Arnold is offline
Old 02-15-2004, 03:28 PM   #5 (permalink)
thanks alot
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Reoccurring intermittent wiper problem aowRS 95.5-2004 Tacomas & 96-2002 4Runners 9 01-30-2006 05:41 AM
intermittent stumbling 3.0 abalagtas Maintenance & Repair Archives 7 06-08-2005 06:02 PM
85 4runner- intermittent wiper relay centraline 95.5-2004 Tacomas & 96-2002 4Runners 8 02-26-2005 09:03 PM
Wiper swap question crancher 95.5-2004 Tacomas & 96-2002 4Runners 1 02-17-2004 04:53 PM
Intermittent squeeling??? Plays_with_Toys 95.5-2004 Tacomas & 96-2002 4Runners 8 02-15-2004 09:56 PM
2009 InternetBrands, Inc.
