| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Interior lights don't work, won't start!!! 98 4runner
#2 (permalink) |
Oh....one more thing, the truck will not start!
#3 (permalink) |
Did you hook it up reverse polarity or something?
Do you get any lights at all on the inside when you jump it? You might try a trickle charger on the battery and check all the fuses to ensure none are blown (both under the dash and in the engine compartment).
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#4 (permalink) |
The battery was hooked up (jumped) correctly, No lights at all in the interior. horn does work. I don't have the remotes for the factory alarm...Would that have anyting to do with it?
Thanks Josh |
#5 (permalink) | |
Quote:
I would remove the alarm (not that hard to take out) or get new remotes programmed for it. You might ask the dealer if you drained the battery like you did, would it prevent starting? I am not sure since I have never tried it myself but I know the viper I have will go off and prevent starting without using the remote.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! Last edited by MTL_4runner; 12-17-2004 at 06:41 AM. |
#6 (permalink) |
Yeah sounds like your alarm has starter disable. The alarm may have a Valet switch. which Should let you start it ???
#7 (permalink) | |
Quote:
__________________
96 4Runner SR5 SC | 3" Revtek Front/OME 891 Rear,Diff/Panhard Drop|AirLift bags|285/75/R16 Nitto Terra Grappler|Eaqle 121 w/TRD Logo|Bilsteins|Cross-Drilled PS w/PF Pads|Silver Reverse Gauges|Custom Grill|Catch-All Floor Mats|Sylvania SilverStar|Weather Tech Visors|Clear Corner/Fronts|Alpine MP3/WMA/CD|99+Headlight/Console Mod|K&N FIPK W/Drycharger|Optima Redtop|Trans-Cooler|Remote Start|PICS|PICS2| |
#8 (permalink) |
Thanks for the quick reply guys! I will try to unplug the alarm unit, but does it make sence that the interior electronics will not work? Is there some kink of main fuse that it could be? Thanks again.
#9 (permalink) | |
Quote:
worth a try to unplug the brain first and see if it helps any.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 98 4runner won't start! | elburritobandito | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 07-18-2007 02:48 PM |
| Will these spacers work on a 98 4runner? | JM | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 06-07-2006 03:28 PM |
| 98 4runner wont start, alarm/starter issue, need help ASAP! | Amir904 | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 01-21-2006 01:46 PM |
| '03 4Runner interior lights | acont99 | 95.5-2004 Tacomas & 96-2002 4Runners | 17 | 03-15-2003 07:41 PM |
