Interesting problem - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-04-2008, 05:09 PM   #1 (permalink)
paxam's Avatar
Interesting problem
all
I have a 02 v6 s.c. when I am between 1800 and 3k light load it feels like the engine is cutting out for a second or two. I looked at the plugs and appear to be fine slightly black inside but the electrode is in good shape. the gap was at .040 to my supprise I regapped them to .031 -.032. also I cleaned the mass airflow sensor,air filter and throttle body. I am assuming it is a coil so I got a new one and swapped it out with each one but still it is dying. I check the resistance of all of the coils hot and cold primary winding and secondary all are with in .5 ohms... I am not getting any codes.
Also I drained the fuel and put fresh 93 + octaine boost in the tank.
any Ideas?
__________________
TRD Supercharger,TRD 7th injector,URD AIC ,Headers,2.5 Magnaflow exhaust,Airfilter,air box mod,flexalite 210 fans,optima yellow top,Warbro 190 ,TRD t stat,ramsey 8000 winch and rear locker mod
paxam is offline
Old 10-05-2008, 12:04 AM   #2 (permalink)
KdF
KdF's Avatar
You seem convinced it's electrical.
Did you change the wires?
Also.......Fuel filter.
Ya, I know but they do not last forever.
__________________
KdF
In Memory of my Only Son Chris
99 Taco Prerunner
Full OME Suspension Replacement
Poly Bushings (all) replacement
Greasable shackles
KdF is offline
Old 10-05-2008, 06:44 AM   #3 (permalink)
paxam's Avatar
the plug wires are 6 months old. NGK wires. fuel filter was done in Jan.
the electrical is a starting point since it is all controled by a computer.
__________________
paxam is offline
Old 10-05-2008, 08:07 AM   #4 (permalink)
KdF
KdF's Avatar
My Dad's Ford years ago had the same symptoms and it turned out to be a bad plug wire. They can come out of the box bad.
Just sayin.........
__________________
KdF
99 Taco Prerunner
Greasable shackles
KdF is offline
Old 10-05-2008, 12:00 PM   #5 (permalink)
jeremy9allen's Avatar
How many miles on those plugs? They can look great but still miss under lite loads. Ford 4.6L are notorious for that. The plugs will look good and be in gap, but have an intermittant miss.
__________________
97 4runner SR5
91 Corolla DX-
92 Camaro rs
87 Shelby Daytona (money pit)
85 C10 slammed (sold to buy a nice oven)
jeremy9allen is offline
Old 10-05-2008, 01:01 PM   #6 (permalink)
paxam's Avatar
I think I found it..
a bad TPS I ohm out the orig and there is a spot that the resistance goes crazyfrom 400 Ohms to 1.2 then back to 420 ohms . I put my spare in and ran it so far no dying and my idle is back to 750 rpm's...
the plugs are less then a year and the wires 6 months or so.
__________________
paxam is offline
Old 10-05-2008, 05:46 PM   #7 (permalink)
That would do it.
__________________
97 4runner SR5
91 Corolla DX-
92 Camaro rs
Old 10-05-2008, 05:57 PM   #8 (permalink)
j-man's Avatar
welcome to the world of bad tps sensors for the 02-04 tacomas, especially for those with forced induction. You will go thru them about every year or so. Last i checked, you couldnt buy them individually, you had to buy the whole darn throttle body, at least for my old 03 dbl cab i had. Good luck.
__________________
2000 4Runner v6 sr5 4x4 5spd: Turbo'ed
99 4Runner v6 Sr5 4x4 5spd: Saw's / OME combo TrueTrac rear
98 4Runner V6 Sr5 4x4 5spd E-locker: Saws / OME combo... EEZI AWN Roof Tent 1.4m
97 4Runner V6 Sr5 4x4 Auto: Saws / OME combo TrueTrac rear
2003 Landcruiser 285 BFG At's and outback roofrack
My Baja Trailer Build: http://forum.ih8mud.com/showthread.php?t=179520
http://community.webshots.com/user/bajaroadtrain
j-man is offline
Old 10-06-2008, 04:57 AM   #9 (permalink)
That's exactly why any real tool box since the mid 90's should have an ODBII reader. This issue could have been found in under 3 minutes (literally).
__________________
'99 4WD 3.4L SR5 AT
DailyDrive is offline
Old 10-06-2008, 07:42 AM   #10 (permalink)
j-man's Avatar
Quote:
no, actually the TPS starts to go bad before a code is ever thrown quite often. So the only real way to check is get a ohm reader and check it just like paxam did.
__________________
j-man is offline
Old 10-06-2008, 01:37 PM   #11 (permalink)
Quote:
see, you haven't even seen an ODBII reader. you might have seen ODBII code readers.
An ODBII reader will show values right on the screen that the ECU sees coming off the TPS. All you do is hook it up, slowly press the gas pedal and look at the values the TPS is sending back. This test actually takes about 10 seconds to perform, if not counting the time to hook up the ODBII reader.
__________________
'99 4WD 3.4L SR5 AT
Old 10-06-2008, 02:38 PM   #12 (permalink)
j-man's Avatar
shnizzle - i learn something new everyday...
__________________
j-man is offline
Old 10-06-2008, 04:12 PM   #13 (permalink)
yeah, you could fix a Model T with a hammer. A carburetored car with a wrench set. But for the last 15 years the first tool out of the toolbox should have been an ODBII reader
__________________
'99 4WD 3.4L SR5 AT
Old 10-08-2008, 12:56 AM   #14 (permalink)
please to recommend an affordable one?
this is good info from all of you and I learned a lot. Is it necessary to spend around $100 for one? I welcome a brand and model number and value the opinions you guys have about these matters.
__________________
99 4Runner SR5 4wd 3.4/5 spd-Ltd woodgrain
Fact. Rear Locker/Diff Breather Ext.
LT265/75/16 Nitto Terra Gs- AR767s
Old Man Emu springs- 881 fronts/890 rears
O/M/E shocks- N91s fr./N86 rr.
All Pro Off Road welded sliders
ARB"Taco"bumper/Gamiviti clear lenses/Hella 500s
Redline Tuning hood struts and no sport hood!
TrueFlow Air Filter inside deckplate modded airbox
Rear wing custom painted in body color (white056)
Newest mods-Crown Vic horns/front rock lights
Ron Helmuth is offline
Old 10-08-2008, 05:14 PM   #15 (permalink)
Plenty of companies make ODBII readers, though I prefer Auterra with a handheld Palm. It will be a bit over $100, but doesn't mean you can't split that and share it with other. The economy is going down the so it's a good habit to get into anyway
__________________
'99 4WD 3.4L SR5 AT
Old 10-10-2008, 04:18 PM   #16 (permalink)
thank you
asked and answered I like these simple threads
I appreciate the recommendation
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
For all of those with the Power Surging Problem! Interesting Problem Found! Texas_Ace 95.5-2004 Tacomas & 96-2002 4Runners 24 06-26-2008 12:14 PM
Interesting electrical problem. Popak2 84-85 Trucks & 4Runners 5 10-29-2006 10:14 PM
Interesting Idle Problem leiniesred Maintenance & Repair Archives 0 11-11-2005 06:33 AM
Interesting Electrical problem NorCalVP 95.5-2004 Tacomas & 96-2002 4Runners 5 09-18-2004 05:24 PM
Interesting A/C problem/observance... rpeAMP 95.5-2004 Tacomas & 96-2002 4Runners 4 02-27-2004 08:41 PM
2009 InternetBrands, Inc.
