Intalling new bushings
Old 02-18-2003, 03:29 PM
DavidO06's Avatar
Hey, i finally ordered and recieved my energy suspension bushings for my factory sway bar. Has anyone else installed them. The factory hole is slightly offset and i didn't know if it would cause a problem with the new bracket. What kind of nuts and bolts did you guys use if you did this mod? I am about to work on it some more, i have just looked at it right now.
Old 02-18-2003, 03:42 PM
Away
Dr. Zhivago's Avatar
Yeah, I bought new nuts, bolts and washers for the sway bar brackets that came with the ES bushings. You will need to grind one side of the washers for the bolts that hold the rear sway bar. I used new nuts, bolts and washers for the front. Check jalaber's site for a write up.
Hope this helps.
Dr. Z
kawazx636
10-06-2021 03:03 PM
live4soccer7
05-11-2016 06:52 PM
punks_is_4x4
02-26-2016 04:29 PM
JRB4Runner2015
09-20-2015 12:29 AM
Pocoyota
09-08-2015 02:41 PM
Quick Reply: Intalling new bushings
