YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 02-19-2007, 11:55 PM   #1 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
installing new shocks and springs
just how hard would it be to replace both front and rear shocks and springs do i need to get a spring compressor or can i just take the weight off the axles and drop the spring out that way ? i dont have clue on how to do it i would like to do it myself to save some money as i dont have any freinds around here to lend a hand
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
mom 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Sponsored Links
To remove this ad, register today!
Old 02-20-2007, 12:32 AM   #2 (permalink)
grimpy's Avatar
Send a message via AIM to grimpy
I did my install myself... A helper would have made it three times easier!
Only the rears would drop out... The fronts will need a spring compressor. Air tools make the work alot easier.
First time I did the suspension on the 4Runner, it was a pita w/o air tools... Second time... I had air tools and had the springs off the shocks in about 15 minutes.
With no prev. experience, no help, and no air tools... I would strongly recommend having it professionally done unless you are ready for a good 4-8 hours of misery...
__________________
2007 Tacoma Double Cab 4x4 TRD Sport 6speed
Pro Comp 6" - Bilstein 5100 front
18x9 Moto Metal 951B - 325/60/18 NTG
Pro Comp Skid - Lund Grill Cover
17x10 Weld EVO Velociti 6 *soon
grimpy is offline
Old 02-20-2007, 01:06 AM   #3 (permalink)
Elton's Avatar
well i guess i may as well have a shop do it just not sure where to go not alot of places around here
__________________
Elton is offline
Old 02-20-2007, 01:19 AM   #4 (permalink)
Elton's Avatar
what if i where to get this http://www.harborfreight.com/cpi/cta...emnumber=95310 and this http://www.harborfreight.com/cpi/cta...temnumber=3980
__________________
Elton is offline
Old 02-20-2007, 01:28 AM   #5 (permalink)
grimpy's Avatar
It's actually very do-able though... Just a pita if it's your first time... If there aren't many places around you... they might charge you an arm and a leg... :X
I've done over 15 suspension installs from BMW's, Acura's, Honda's, and Toyota's... I would say the 4Runner is one of the easiest simply because almost everything is right in front of you.
All you need are the proper sized tools... a 3lb sledge hammer, fitted gloves, a 2+ ton floor jack would be nice, jack stands, PB Blaster, and spring compressor.
With this said... I wouldn't pay more than $200 to have it done professionally, heck at $150... I probably wouldn't either...
__________________
grimpy is offline
Old 02-20-2007, 01:33 AM   #6 (permalink)
grimpy's Avatar
The impact wrench requires an air compressor... If you have air tools... It would be alot easier!
As far as the spring compressor goes... I would recommend getting a more expensive set... I have the craftsman http://www.sears.com/sr/javasr/produ... UTO&ihtoken=1 You definately don't want to skimp out on this...
__________________
grimpy is offline
Old 02-20-2007, 05:51 AM   #7 (permalink)
gpcollen1's Avatar
Doing the rears is relatively easy.
Doing the fronts - I recommend taking the units out complete. That means only removing the top 3 nuts and the bottom bolt. Bring them to a shop and have them swap the components.
I was having a bear of a time with my spring compressor -- think i was stripping a nut. So I brought them to my buddy's shop - Subaru . Used their machine and it took all of 10 minutes for both - SAFE and easy!
G
__________________
'99 SR5 Sport - Desert Dune: AirRaid MIT, OEM Air Filter, Toyo 265/75/16 ATs, Deckplate, PP Springs and Bilsteins, Cheapo nerf bars, Injector replacement impending
gpcollen1 is offline
Old 02-20-2007, 11:24 AM   #8 (permalink)
FUZION's Avatar
G
:bigclap:
GOOD LUCK
__________________
Scooped 97 Black 4Runner
*Black 99' Headlights, corner lights + taillights *Tundra Calipers/Sequoia Brembos *17" Black Sequoia wheels/ 32" Michellins *Hilux Surf Emblem *Taco Skid Plate *Waag Guard *Black Nerf Bars
*5% Tint *Clarion Dxz545mp *2 12" Fosgate Punch Z *ProfileC400 Amp *Red glow guages
Quote:
i like it ! makes me wanna go out to the garage and throw rocks at my fj .
FUZION is offline
Old 02-20-2007, 11:32 AM   #9 (permalink)
Elton's Avatar
im going to get some prices qoutes just you wait to hear what they charge here on the cost
__________________
Elton is offline
Old 02-20-2007, 12:52 PM   #10 (permalink)
frodin1's Avatar
I found that you need to have jack stands tall enough to make it possible to drop the axle down far enough.
frodin1 is offline
Old 02-20-2007, 01:03 PM   #11 (permalink)
Send a message via AIM to Localmotion
do not use that impact gun on the spring compressor...if you do, you will break it. I used it and it broke.
ALso, invest in some nicer ones or again, they will break.
If you have never done it before or anyone with you have not done it, i wouldnt suggest you doing it on your own. You will also need to install the diff drop. Ask for help, maybe locals will be able to help.
Localmotion is offline
Old 02-20-2007, 01:18 PM   #12 (permalink)
gpcollen1's Avatar
[quote=Localmotion;50439658]do not use that impact gun on the spring compressor...if you do, you will break it. I used it and it broke.
QUOTE]
I did see a set in Sears the other day that looked a bit beefier than the ones I have.
__________________
Old 02-20-2007, 03:32 PM   #13 (permalink)
Elton's Avatar
alright i got a quote for 200 bucks and the local import shop
__________________
Elton is offline
Old 02-20-2007, 03:44 PM   #14 (permalink)
seanz0rz's Avatar
Send a message via AIM to seanz0rz Send a message via MSN to seanz0rz
dont get the harbor frieght compressors, i blew the nuts off of them with my impact gun. horrible product
rent them from autozone or kragen/checkers/schucks. actually, rent two pair, it makes it so much easier!!!!!! you can use an impact gun on these. they are 43 bucks, get all your money back when you return them, even if you break them
__________________
1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Sonoran Steel #1, 285/75R16 BFG A/T, Elocker retrofit, Tundra calipers, brembo blanks, hawk lts pads, CarPC in custom center console with molded Indash touchscreen, KC daylighters mounted on Surco Safari rack, Custom sound system, 4xinnovation sliders, sleeping platform, Shrockworks front bumper, 1" 4crawler body lift, etc.
Pictures
Photobucket is being updated, if a picture i posted no longer works, please PM me.
seanz0rz is offline
Old 02-20-2007, 03:47 PM   #15 (permalink)
Elton's Avatar
lol im not going to do it just wish i lived else where so i would have someone that could help me
__________________
Elton is offline
Old 02-20-2007, 04:04 PM   #16 (permalink)
seanz0rz's Avatar
if you wait till the summer... where exactly are you in oregon? off the 101 or 5?
__________________
Pictures
seanz0rz is offline
Old 02-20-2007, 05:37 PM   #17 (permalink)
if you do a 3 inch lift on a runner do you still have to do a diff drop?
huskres is offline
Old 02-20-2007, 06:21 PM   #18 (permalink)
Elton's Avatar
Quote:
about a 2+ hour drive from I 5
__________________
Elton is offline
Old 02-20-2007, 06:21 PM   #19 (permalink)
Elton's Avatar
Quote:
i would there cheap
__________________
Elton is offline
Digg this Post!
