Installing new driveshaft
Old 01-18-2016, 09:28 PM
Hrddrvs's Avatar
Angry Installing new driveshaft
2000 Tacoma 2.7 Single Cab
Hello, I ordered a new driveshaft and am wondering if there is going to be an issue installing it correctly as far as balancing. I know on my old shaft I had paint marks aligning it. I have'nt received the shaft yet and I'm guessing it could take a few tries. Anyone have experience with this? Thanks.
Old 01-20-2016, 12:37 PM
vasinvictor's Avatar
The marks you used were to make sure the driveshaft was phased correctly if you pulled the shaft apart at the slip yoke. When you get your new driveshaft, it will be put together, and you will not need to worry about marking it, unless you plan on pulling it into two pieces. (Don't do that). The shaft will be balanced and ready to install.
Old 01-20-2016, 05:13 PM
Hrddrvs's Avatar
Thanks for the info. vasinvictor. It makes total sense.
anniesball
01-16-2016 04:29 AM
JCBond
01-11-2016 06:31 AM
Tanner Yarborough
01-07-2016 09:15 AM
Sky.A
12-20-2015 11:34 PM
Quick Reply: Installing new driveshaft
