Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
installing locker NOW, need help.
i'm have the 3rd member out and the ring gear off. how do i get that little pin out so i can get the big pin out?
__________________
SOLD 92 Pickup extra cab 22RE 4x4. 4" Superlift, BFG MT 33x12.50x15, Rockcrawler Streetlocks 15x10, aussie, lockrite, 4.88. 2003 4Runner Limited |
| Sponsored Links |
#2 (permalink) |
You need a set pin punch. ACtually any punch will work. If I remember correct you shouldn't have to remove the whole set pin. I also believe the carrier that the set pin is in has a small flap of metal covering the setpin on one side, maybe both. Look for that and pry it up. I did and ended up breaking it clean off. I then had to mushroom the carrier on re-installation to prevent the setpin from coming out again. Does this make any sense? Anyways if your having trouble getting the setpins out make sure you try to go the other way with them. I really think they only come out one way, I figured that out after beeting the shi*t out of them. Good luck.
__________________
2008 Tacoma TRD Access Cab v-6. 97 regular cab tacoma 33x9.5bfg at, 4.10 gears, custom sliders, custom rear bumper, 4xinnovation tube doors, lockright. CB: Connex 3300hp Radio driving a FatBoy Amp doing around 1000watts on AM. Antenna: Monkey Made MM5 -=NO BAMA 08 =- |
#3 (permalink) |
punch out the little pin
grind out the dented in part at the big end of the hole a little bit.
Use a punch to push the little pin out the hole. Now you can remove the ring gear if you haven't done so already and slip the big cross pin out of there. It sounds like you are working on a 4cyl diff and putting in a lockright or ez locker. Last edited by leiniesred : 08-05-2005 at 12:10 PM. Reason: clarity |
#4 (permalink) |
4 cylinder diff, aussie locker. close. turns out i have an oddball 30 spline yoke and have to get the conversion yoke from PORC. i wish i had the normal 27 spline yoke. kinda gay i think.
__________________
#5 (permalink) |
Sheesh, what luck.
__________________
#6 (permalink) | |
Quote:
yeah, no ลลลล, i was so pissed when i figured it out. it's $71 to get it 2nd day overnighted to me, or whatever it's called. the part costs $39. i was pissed. now i can't drive my truck for another 4 days.
__________________
#7 (permalink) |
Sounds like something that would happen to me... grr.
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| WTT 4.56 e-locker for 4.10 e-locker | 91diesel | Axles/Suspensions/Tires/Wheels | 2 | 06-18-2007 07:31 AM |
| Toyota e-locker or ARB air locker?? | ranma21 | Offroad Tech | 34 | 10-04-2004 09:15 AM |
| Installing ARB locker on a 3rd Gen 4Runner | ranma21 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 08-27-2004 12:33 PM |
| Installing a Locker on a 3 gen. 2wd | Bigkahuna808 | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 06-10-2004 03:12 PM |
| Help!!! Installing my locker! | OneTrickToy | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 07-05-2003 07:50 PM |
