Installed LPD 4454 Trans Cooler *PICS* - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-06-2006, 09:38 AM   #1 (permalink)
JHRRLD's Avatar
Send a message via AIM to JHRRLD Send a message via Yahoo to JHRRLD
In preparation for installing the TuRD SC and URD fuel goodies I ordered one of these to help keep my trans cool. I just installed it this weekend. In the next month or so I'll be sending IPT my valve body to be modified as well.
This is how I mounted the cooler:
Bottom mounts:
Just some information. I found in my case (00 T4R 5VZ) the OE trans cooler that is part of the radiator accepts the fluid from the trans on the passenger side of the vehicle and returns it on the driver’s side. After going through the OE cooler my lines originally went around the bottom side of the radiator and up to the cooler. I later realized after getting done that the skid plate wouldn't reinstall and the lines might be easily damaged while off roading :
So I changed the lines to go through where the AC condenser lines run. It was necessary to remove the headlight in order to get my large hands into that small space to zip tie things up. I wrapped the 3/8 hose with some larger hose that I picked up from Home Depot to protect it: This won't negatively affect the AC will it?
You can hardly see the lines in this pic. You can also see my 18" Perma cool fan that I installed a couple months ago.
This is what it looks like with the grill reinstalled. (I know she is VERY dirty and will be getting a bath and clay bar job + wax soon):
Through lots of searching this I how I thought it should be done.
Let me know what you think please
JHRRLD is offline
Old 11-06-2006, 01:14 PM   #2 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
looks good
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
sister 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 11-06-2006, 02:55 PM   #3 (permalink)
JHRRLD's Avatar
Fluid Level
Well I lost only a little bit of fluid during the installation. I had read the cooler itself uses anywhere from 1/2 to 3/4 of a quart of ATF itself. I added about 3/4 of a quart and then checked again after I drove about 45 miles at ~80mph or so. I thought that would get the fluid nice and warm. I guess this little cooler does a stellar job because when I checked it again I assumed it should be the the Hot range on the dip stick. It was a little over the cool marks. I added some more ATF to bring it into spec. Rechecked it this morning after sitting all night and it was at the same level Do I need to pull some fluid out now??
JHRRLD is offline
Old 11-06-2006, 02:56 PM   #4 (permalink)
JHRRLD's Avatar
Quote:
Originally Posted by Elton View Post
looks good
Thanks
JHRRLD is offline
Old 11-06-2006, 11:16 PM   #5 (permalink)
Nice install. I have the Tru-Cool LPD 1678...The big one. In the winter I'm lucky if the gauge hits 110*. During hard wheeling or towing in 95+ heat it may hit 210 but it drops rapidly when idling or gets put on the freeway where the TC can lock up. During summer cruising it's around 140-160.
SLC97SR5 is offline
Old 11-07-2006, 10:58 AM   #6 (permalink)
99SR5's Avatar
Send a message via AIM to 99SR5
i see you have an electric fan
__________________
87 4Runner SR5
- some spacer lift with cranked torsion bars
- 31x10.50/15 BFG Mud Terrain KM2 (amazing tires!)
99 4Runner SR5 Highlander-auto
- K&N filter, removed intake elbow, open air box, deckplate mod
- 265/75/R16 BFG MT's on stock 5 star's
- raised rear diff breather
2003 Mach 1
-full bolt ons, 4.10 gears, tuned by Excessive Motorsports; 307 hp, 326 tq
99SR5 is offline
Tags
34, 4454, cool, cooler, hose, installation, long, lpd, lpd4454, tru, trucool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Trans Cooler Question woodshunt 95.5-2004 Tacomas & 96-2002 4Runners 13 11-17-2008 11:37 AM
Engine Oils or Trans Cooler? SnoViking Offroad Tech 3 03-19-2006 04:58 PM
2nd Gen. Trans Cooler TrevorR 95.5-2004 Tacomas & 96-2002 4Runners 0 09-29-2005 01:41 AM
Trans Cooler Installed.. WT 95.5-2004 Tacomas & 96-2002 4Runners 6 12-05-2004 06:57 PM
Got My Auto Trans Cooler Installed! Tell Me What You Think corvettelvr73 95.5-2004 Tacomas & 96-2002 4Runners 10 04-27-2004 09:12 PM
2009 InternetBrands, Inc.
