installed 3" BL
installed 3" BL
I installed 3" body lift a couples days ago.... *Nevermind, it turned out to be a busted CV* I'll post some pics of it on the weekend!
I have another question. The idle jumps just a little going from 700rpm to 800rpm every 30 seconds or so. That happens ever since I replaced MAF(5,000ish miles). I was thinking maybe time to clean throttle body? Is it normal?
I thought it might be more helpful from people who have body lifts on it. They might have same problem. I think its more like clunking. not clicking. My 4Runner is still driveable but dont want to ignore it.
Did you trim all the zip ties? Something might be hitting one as it spins.
Only a couple things you mess with on the body lift and that is body mounts, radiator and steering extension. That is where I would look first (and the zip ties).
1 Post
Is it, just by coincidence, the CV on the left? Is it the fan in the schroud?
As far as the RPMs go, I have seen that on mine before. I would reset your computer especialy if you didn't after the MAF. To do this just remove the negitive battery cable for a minute then reattach. Your 4runner may not run the best untill the computer "learns" all of it's settings. It shouldn't take long.
punks_is_4x4
08-21-2015 01:35 PM
Esibnitsud
07-30-2015 08:19 PM
