Inner CV boots have a small leak
When I changed my oil, I noticed that my inner CV boots have a very small leak between the boot and axle. Since the leak is small, will I be ok just changing the clamp?
I did a quick search and only found "torn CV boot" questions.
I'd check at NAPA for the right size clamps and go that route first. But go ahead and replace them before it's too late.
You'll have to cut the old clamps off. To make things much easier, buy new clamps that will fit around the boot/axle shaft without having to remove the axles.
Be careful with the hose clamps, since some have experienced the "holes" in the hose clamp cutting the CV boot (just like they cut into a hose when tightened too tightly. A safer alternative is using zip ties and tightening them by pulling on the tab with a pair of pliers to get it nice and tight. I put zip ties near/on top of the OEM clamps.
"b" is easily taken care of with a good degreaser bath before putting the tie on. But i didn't notice it until after it had been popped off "for a while". oops.
Thanks for the info guys! The thing that makes me upset is the the dealer replaced all my CV boots because they said that the inner boots were leaking.. This was a few months after I bought it, so its out of their warranty.
Anyways, I will check with some parts stores and see what options they have.
Dealer response to leaking inner boot
I just lifted my 3rd gen and noticed some leakage on both my inner boots. I called my dealer service buddy and he said you don't have to worry about minor leakage. When I asked him if I should attach a hose clamp, it said that wouldn't be a bad idea, but now that I see the zip tie suggestion, it sounds alot better...
Cameron
Cameron
BeMiceElf
10-10-2015 09:40 PM
FS[SouthCent]: TX Third Gen UCA and LCA low miles Taco
KyleT
07-21-2015 07:54 PM
Avenged
07-09-2015 07:55 AM
