Injectors
Injectors
ok i need new injectors for my 22re, it has intake, ehuast and high flow cat and headers soon. What would be the best injectorswill stock just do or if i get ones with more putput will i get any increase in power?
Your ECU programmed for the stock size injectors. If you put larger then stock ones in it will run overly rich and that will kill power and can cause serious engine damage.
Unless you have converted the engine over to forced induction, the stock size is all you need.
Gadget
Gadget
