injectors
injectors
I am in need of new injectors for my 95 v6 4Runner. Which ones should I get? 175 per injector is just too damn much, but I know the trouble you have with the refurbished ones. What to do?
I just put in reconditioned ones. I am not really interested in buying these every 10,000 miles. I liked the 175,000 miles that I got from the factory ones. I woud be interested in TRD, but I have not found those for 95 models. Does anyone know about Supra ones? I searched this forum and all I found were people suggesting it. Anyone done this?
Where can I get good injectors?
well I am not a injector wiz but if you increase size without doing engine mods you will run rich. I am sure the cpu will try and compensate for this. but if the stock fuel curve is set up to run with X size inj and you increase it you will most likely run too rich or not at all. you may have to install a piggy back cpu to adjust your fuel curve. the place Gadget sugested is a block away from where I live ....cool.
