Injector question
Old 12-06-2003, 09:21 AM
bamayote's Avatar
Unhappy Injector question
Can anyone offer some info on where to purchase new or rebuilt injectors? the stock ones are $180/piece. I cant find anyone in north Alabama who knows what i'm talking about when i say "ultrasonic cleaning". Even the dealerships.
i've had a lean code prob and when i changed plugs again i noticed a white cast on the passenger plugs.
I thought i'd give a go at changing the passenger injectors since their pretty easy to get to.
thanx
brad
99 tac 4x v6
125k miles
changed... o2 sensors, cleaned maf, fuel filter, pcv valve, listened for vac leaks, new tps.
Old 12-06-2003, 12:52 PM
MTL_4runner's Avatar
Have you cleaned your MAF sensor yet?
What was the exact code # you got?
Old 12-06-2003, 12:55 PM
bamayote's Avatar
yeah.......checked the maf AGAIN lol
p0171 bank one lean. i cleaned the maf again the other day and checked the hot wire, but everything looked great. i'd changed air filters the last time i cleaned it as well.
it's really cold natured now as well! and kinda surges around 2k rpm's after it warms for a while.
anyone ever changed their engine coolant temp sensor?
Old 12-09-2003, 06:22 PM
Unhappy99's Avatar
Take the MAF/IAT module off again and this time really clean the MAF hotwire, not just the IAT sensor.
Old 12-09-2003, 08:14 PM
cstary's Avatar
vacuum leaks cause lean codes too . . . check the lines for a disconnection or cracks.
creed
Old 12-10-2003, 09:38 PM
Mossback74's Avatar
Lightbulb
And run some Techron injector cleaner though too. It helped my 2nd gen. Be sure to get the "techron" not the "With techron"
Doug4320
03-24-2018 10:11 PM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
TJWilly
07-31-2015 02:05 PM
pyramid
07-29-2015 06:53 AM
Quick Reply: Injector question
