Info on my 3.4l supercharger
Alright so I have had my 4Runner for about 3 or 4 months and want to know some more info about the supercharger and any other maintenance I should do with my engine.
And I have done quite a bit of searching on the subject and haven't found all I want to know so I was hoping you guys could help me out.
sooooo what kind of upgrades can I do to my engine to optimize the sc, I have heard that you shouldn't put in an upgraded air intake with the sc for some reason but wanted to double check with some of you guys. and also what kind of maintenance, if any, I should do(besides change the oil alredy did that).
and if there is anything I am oblivious to let me know
Thanks for any help!!!!
Here is a candy store of goodies for the SCer, I'd start with the SCer fuel upgrade kits. If you have any money left after that look into smaller pulleys and water/meth injection: http://www.urdusa.com/
More info including maintenance http://www.gadgetonline.com/Super.htm (note some links appear to be broken but if you capitalize the subject in the address they will work, for example capital "F" in this one gets you there) http://www.gadgetonline.com/Fuel.htm
Capital P and F in this one works: http://www.gadgetonline.com/PingFix.htm
Capital F here: http://www.gadgetonline.com/Fuel.htm...Second%20ESC1:
Gadget's research on this is especially relevant for you since you have a 96 model truck and that's what Gadget started with. They have less fuel capacity than the later models.
Might try narrowing your search terms down a bit...I found these pretty easily and they have some great info in them.
https://www.yotatech.com/forums/f2/s...g-3-4-a-72220/
https://www.yotatech.com/forums/f2/s...od-done-70844/
Fink
Fink
Thanks for the info mtgoat and fink! I will look into those. I guess this would have been good info before but my engine was swapped in from a 01 Tacoma so I have to newer 3.4l.
Give gadget at www.urdusa.com/ He'll make sure you're safe with the sc.
You could add a 7th injector
run bigger injectors and a controller
methanol injection...
It all depends on what you want to accomplish.. run it safely? or make the the biggest bang.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
buckz6319
08-05-2017 03:50 AM
anniesball
10
09-15-2015 05:41 PM
anniesball
09-09-2015 09:55 AM
anniesball
09-07-2015 11:20 AM
