inconspicuous switch for non smokers - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-23-2006, 03:41 PM   #1 (permalink)
Here's a reprint of my post from a different section that may benefit more of us.
Hi all, It's great when you can post a thread that might help others!
Any how, to make a long story as short as possilble.
First of all, I'm not responsible for anybodies actions or results after reading this. I'm just posting a actual experience.
Today I was installing a stereo in my runner , all went well thanks in part of all of the excellent threads regarding stereo installs! .
But my HU is the kind that activates the power antenna everytime I turn the unit on in CD mode, that means it will continually be cycling up and down wearing the poor thing out. So I located the wire that does this and thought , I could wire a switch to this very easily, but I did not want a obnoxious switch sticking out of my dash or a hidden one where I had to bend over while driving.
Started looking around the dash to see what I could use. And then it came to me..... Why can you use the CIG LIGHTER ? Think of it? It has B+ and B- hook up to it, and the element is the load , the lighter itself, when you go to push it in ,is just a switch!!
I took my multi meter out and found out that the center post and the large spade are connected when it is push in ! Al man, way cool . This is my switch!
I checked the amp load of the wire to the power antenna unit and it only draws 7ma B+, hardly anything ( goes to 85 or 86 of the relay) . I removed the lighter and completly disassemble it , b/c the center post nut has to be removed.This will take patience since man has not evolved the third arm yet. I installed 2 longer leads to the 2 terminals at the lighter and used spade connectors, so when I take the dash apart again ,there is enough slack to do this and I can disconnect it also.
I wired the P/A wire from my stereo to these 2 connectors at the lighter, plug in all my stereo connectors and push in the lighter and wah la!! the antenna went up . Pull the lighter out , and the antenna goes down . This works so sweet! And you can't even tell where the switch is! The worst that could happen is if the lighter did not make contact, no P/A.
I'm thinking of possiblities of using this, anything that you can wire a relay to. Use the lighter for the trigger for the relay! If there is something I'm missing here as to why this can't be use in this manner, let me know. Also if you still any questions , let me know. BTW the stereo sounds great!!
__________________
Work smarter not harder
99 t4r SR5 3.4l A/T 4x4
Hella HIP's headlamps, wired DRL to factory switch
w99t4rweos is offline
Old 12-23-2006, 03:49 PM   #2 (permalink)
drguitarum2005's Avatar
Location: Houston (home), Atlanta (school), Cincinnati (work)
Send a message via AIM to drguitarum2005
so are you pressing in the stock lighter? wouldnt it pop out after so many seconds and then interrupt the circuit? i dont know what kinda device i'd be using that would need to be activated for 10 seconds only...
__________________
-David
2000 Taco TRD Access Cab
v6 | 5spd | 33" BFG A/Ts | 33" PC Mud Terrains | OME 882's | Bilstein HD struts front | Rancho shocks rear | Chevy 63" leaf spring swap | Custom sliders | Custom front bumper |3" BL | U-Bolt flip | Flowmaster exhaust | Kenwood Speakers | Grey Wire Mod | Aux. Reverse Lights | Deckplate Mod | Lots of lights
Pictures
drguitarum2005 is offline
Old 12-23-2006, 03:56 PM   #3 (permalink)
Quote:
The factory wires are diconnected, so the lighter is inoperable. I took the P/A wire and cut it in 2 and connected them to the lighter spade connectors.
The lighter will stay in indefinitly.
__________________
Old 12-23-2006, 04:01 PM   #4 (permalink)
oh ok i missed that part. sounds good to me.
__________________
-David
Pictures
Old 12-23-2006, 04:30 PM   #5 (permalink)
Alperovich's Avatar
nice!
__________________
~Alex
My cars..
93 Acura Legend cpe 6spd ; 93 Legend cpe auto (parts) ; 90 T4r V6 5spd ; 82 Yamaha Maxim 550
Past cars...
02 Dodge Durango ; 89 Lude 4ws 5spd totaled :( - not by me! ; 96 Chevy Blazer 2dr
Other cars in the fam
05 Dodge Grand Caravan (dads) ; 01 Dodge Ram B3500 (dad's) ; 01 Civic (moms) ; 00 Lexus RX300 (sisters) ; 96 Cherokee (sisters bfriend)
Alperovich is offline
Old 12-23-2006, 04:51 PM   #6 (permalink)
rdharper's Avatar
Sounds like a cute way to disguise a kill switch.
__________________
Richard
"Science by consensus... is not Science." Richard Harper -1988
'94 Toyota 4Runner V6 3L 158K miles 14mpg
'85 Toyota 22rec 4WD SR5 LB PU 208K miles 18mpg
'08 Honda Ridgeline RT 2.6K miles 16mpg
'06 Honda Rincon ATV 410miles/65hrs 22 mpg
rdharper is offline
Old 12-23-2006, 08:00 PM   #7 (permalink)
2KTacoma's Avatar
The heat generated by the current flowing through the cigarette lighter is what causes it to pop. by running only a little current through it it will not heat up enough to pop out.
__________________
Silver 2000 Toyota Tacoma Extended Cab V6 5spd SR5
Now with URD short shifter and
Milled polyurethane shifter seat
Hella FF1000 Driving Lights
2KTacoma is offline
Old 12-23-2006, 08:08 PM   #8 (permalink)
ChickenLover's Avatar
What an awesome idea.
I have a power-interrupt kit for my winch. Instead of putting in another switch, I used an existing one as well. I now have to engage my ECT button for my winch to have power.
__________________
95 4Runner, 3VZE , 141k, 4WD, Auto. (Head gaskets replaced at 106k)
ChickenLover is offline
Old 12-23-2006, 08:57 PM   #9 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
thats a good idea...my antenna is broke so i pulled it up and unplugged it as i barley listen to the radio
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
sister 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 11-04-2008, 08:53 PM   #10 (permalink)
Surfgromdave's Avatar
I just did it to my 99 4runner. its awesome!
Surfgromdave is offline
Old 11-05-2008, 11:28 AM   #11 (permalink)
mikes19984x4's Avatar
wish i would've thought of that 2 years ago when i put a switch on mine, but oh well, it's just one of those little micro switches on the side of the console, so no big deal...lol. cool idea man
__________________
1998 4Runner SR5 4x4
3.4 w/5-speed & E-Locker
Deckplate & ISR mod w/K&N, 2.5-inch Exhaust w/40-Series Flowmaster
Centerforce Clutch
Bilstien Shocks, 265/75/16 Buckshot Mudders
Sylvania Silverstars, Hella 500s on front bumper (no longer), Orange Gauge Lights, JVC Arsenal Head Unit, Pioneer REV-Series Speakers
More mods to come...
mikes19984x4 is offline
Old 11-05-2008, 11:50 AM   #12 (permalink)
1styota4X4's Avatar
so just so i follow you its not enough to heat up the element? Cause if it was My parents had an old econoline van and the circut shorted somehow and the cig lighter melted the plastic around it cause it got hot...Just something to be aware of and to keep an eye out for
__________________
NEW***
1985 lifted locked dual cases bumpers and sliders now my daily!
1985 Stock Had to do head gasket and some other minor things left.
1983 Hilux 4X4 SR5 4 Sale
3" Rough Country Lift 32" Goodyear Wranglers. Custom bumpers being made!!
1995 4Runner 4X4 V6 SR5*****TRADED
1styota4X4 is offline
Old 11-05-2008, 12:24 PM   #13 (permalink)
surf4runner's Avatar
Quote:
Originally Posted by 1styota4X4 View Post
...and the circut shorted somehow and the cig lighter melted the plastic around it cause it got hot...
another reason not to use chinese made crap !
a decent lighter socket wont melt and short from the heat generated by the lighter element.
__________________
sarcasm noted...and appreciated
im with the banned
Quote:
Originally Posted by fustercluck View Post
I was traumatized. I had nightmares of trained attack tupperware beef-logs chasing me all night! Don't bend over, Fuster!!!!!
Quote:
Originally Posted by Lysmachia View Post
Just pile us nekkid in an engine bay and drizzle us with gear oil and watch the fun!
surf4runner is offline
Old 11-08-2008, 08:08 AM   #14 (permalink)
The wires going to the lighter are from the trigger side of the relay which only draw a few milli amps, I have not had any heat generated when using it .
If you have heat in your lighter after this mod, then you have hook up the wrong wires.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Alarm toggle switch near light dimmer switch on '00 Sr5? stangman39 95.5-2004 Tacomas & 96-2002 4Runners 17 02-25-2009 11:07 AM
inconspicuous switch for non smokers w99t4rweos General Electrical & Lighting Related Topics 10 05-16-2006 07:42 AM
Passenger smokers.... Toys-R-Us Off Topic Talk 38 03-29-2006 01:06 AM
Cigar smokers? KING Off Topic Talk 18 11-20-2003 08:35 AM
2009 InternetBrands, Inc.
