Im in the middle of changing my CV boot...Question!!
Old 12-05-2004, 04:56 PM
BajaRunner's Avatar
Okay, Im geting ĊĊĊĊing PISSED.
The part that I thought would be easy is turning out to be the worst nightmare.
HOW DO YOU GET OFF THE OUTER (VISABLE) C-CLIP OFF OF THE ˟˟˟˟˟ING TRIPOD BEARING?
Are there C-clip pliers or something that opens them up so you can slide them off??!?!?!? I've been prying at this frigging thing for 2 hours now, and Im gonna jump through the wall soon If i dont get it offf!!!
Old 12-05-2004, 05:16 PM
waskillywabbit's Avatar
Talking
LOL
Snap ring pliers.
k-bomb's Avatar
There is a tool called "snap ring pliers" designed for those tricky terds. They make them in all different shapes depending on the different size and shape of the c-clips.
I've successfully removed them using a pick tool set too. You may have to use a couple small flat head screw drivers if you do not have picks or snap ring pliers.
But you should be able to find either tools at autozone or shucks.
Here is an example I found on eBay of snap ring pliers.
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Good luck.
Old 12-05-2004, 05:35 PM
BajaRunner's Avatar
OKay, I just thought about that.
I already bought them at the autopart store, and got that first C-clip off.
Now I cant find the second c-clip.
Goddamnit.
Old 12-05-2004, 05:50 PM
BajaRunner's Avatar
I have to pull the tripod bearing up (towards the diff. end) to expose the second c-clip?! Where the ĊĊĊĊ is it.
If I slide it down towards the outer cv, It get stopped by the lip on the axle itself. If I slide it up towards the differential, I see no smaller C-clip.
What am i doing wrong?
Old 12-05-2004, 05:54 PM
BajaRunner's Avatar
AAAA HA!
There WAS NO "inner C-clip". I just pounded it off with a rubber mallet and it came off.
screw that ˟˟˟˟. im puttin my new cv boots on now
Blamalam
03-12-2022 07:34 AM
jashoeuh
11-26-2017 07:01 AM
Tonetrk
08-06-2015 10:06 AM
Jeffreynmandy
07-18-2015 08:26 AM
smiley52
07-11-2015 05:16 AM
Quick Reply: Im in the middle of changing my CV boot...Question!!
