Ignition Cylinder Replacement Question
So the prized ride has been in the shop for a while (see previous accident post) due to trouble finding parts and all that. As a result, i've been out of it / slightly down because I haven't been able to drive around as I want for about a month and a half.
So it is supposed to be out of the shop this week.
Two things I need to do (was one the list pre accident) is fix the stuck key in the ignition and seal my rear axle.
The ignition cylinder- I am looking at both of these and in all honesty I am completely lost on which is the best route.
The complete seems reasonable only for the fact that it is a complete for around the same price.
Thoughts?? Should I look elsewhere?
complete or cylinder
I'm not sure if Toyota's are sensitive w/ VATS as far as the key code combinations. Your best bet is probably call a lock smith and and have them to re-key the lock cylinder. It may even be cheaper. When I do a lock cylinder I always try to convince the customer to pay extra to have us sub out the work to a trusted clientele of mine to re-key it. The tumblers are quite aggravating and if you lose the combination at any time then goodluck trying to have a dealership just hand you the key codes by your VIN # It would also be in your best interest to have a locksmith because you will have the same tumbler codes that fit your doors.
yeah, i considered that. but I have a remote to open the doors and not completely against walking with two keys. my major issue is to avoid having to shift gears rapidly to get the key out.
spoke with a dealer last night and the approx cost is about $80 so I think I may go that route and then look into the re-key option depending on cost.
TURBOrunnerNM
07-22-2015 11:01 AM
Avenged
07-09-2015 07:55 AM
