IFS and ADD Help!
Old 06-30-2003, 05:52 PM
Sandman's Avatar
IFS and ADD Help!
Need a little help...
I just pulled my IFS diff out of my 4cyl 4runner, ADD and all. I have another carrier with new gears and a truetrac but no ADD. Problem is, the new carrier doesn't have the side axle tube so I want to use my ADD tube with the new carrier.
I took the ADD tube off the old diff, but can't get the stub part out of the diff. How does it come out so I can stick it in the other diff?
Thanks for any help!
Old 06-30-2003, 09:08 PM
Firefyter-Emt's Avatar
it should just pull out... It can not have a clip on it due to the design that you have to pull them before the diff. You may just have a round retaning clip on them that is made to pull out. But seriously dude... Buy some Aisin hubs and install the axle with out the ADD.. I wish I had kept the solid tube and stub shaft from my parts truck when I left the body shop I worked at, it would of been in my truck by now.. one less thing to break.
Old 07-01-2003, 04:20 AM
Sandman's Avatar
Yeah, I know. I wish I had that straight tube. Maybe I'll wait until I find one... would be a pain to have to go back and pull the diff again. I do have manual hubs, however.
Old 07-01-2003, 01:00 PM
I am bad.. I didn't notice you said you don't have the side tube... I do think you can put it in with out pulling the diff though..
Old 07-01-2003, 05:37 PM
Say, What exactly is ADD?
Old 07-01-2003, 05:58 PM
Cebby's Avatar
Automatic
Disconnecting
Differential
kawazx636
10-06-2021 03:03 PM
A2theK
10-14-2015 07:10 AM
Badlander
10-10-2015 08:05 PM
dirk89
10-01-2015 05:15 PM
JookUpVandetti
09-30-2015 08:58 AM
Quick Reply: IFS and ADD Help!
