If I may ask? HELP!
Old 01-08-2005, 03:10 PM
NathanBERG's Avatar
Question If I may ask? HELP!
Forgive me but I am going to ask a question about a 96 Camaro v6 I have a very bad coolent leak coming form some where in the front of the motor. I have checked all the hoses and seals on the water pump and around the thermostat and no leaks . If anybody has some educated idea as to where the water may be coming form I would love to hear it
Thanks and sorry for the Chevy question :pat:
Old 01-08-2005, 03:18 PM
JEDI87's Avatar
Check between the head and the block,could be a bad head gasket,and the freeze plugs.
Old 01-08-2005, 03:27 PM
mt_goat's Avatar
Maybe the radiator is leaking?
Old 01-08-2005, 03:33 PM
terryjmatthew's Avatar
Timing cover?
Old 01-08-2005, 08:57 PM
NathanBERG's Avatar
Thanks for the ideas Guys! I am going to take it into a shop and have it checked out I guess.
Old 01-10-2005, 06:18 AM
ozzfan1JC's Avatar
Check these
Water Pump and Intake Gaskets
Old 01-10-2005, 07:27 AM
Ironmike4x4's Avatar
What year and engine? The newer one with the 3.8 had problems with intake gaskets leaking (or any chevy with 3.1 3.4 and 3.8 engines) Also check for headgasket and water pump leaking.
Old 01-10-2005, 08:18 AM
its2slo's Avatar
heres a chebby guy, they are notorious for upper intake manifold gasket leaks and should be your first guess, of coarse its just a guess. good luck. if they were built like toyotas youd just be replacing headgaskets, lol.
Old 01-10-2005, 08:34 AM
hilandfrog's Avatar
do 33 fit in those wheel wells? witch trasfer case are you using? any plans for mudding this weekend?......just kidding good luck with your problem. sounds like intake. I think there is a big gasket pan that screws up from time to time has it been running hot or low oil pressure, both of these will warp, melt, move gasket?
Old 01-10-2005, 02:41 PM
You ain't lying. I am so used to doing intake jobs I could probably do it in my sleep now. I dont understand why GM still uses the gaskets if it is the problem in the first place. I'm so glad I bought a Toy instead of that lifted Tahoe. At least mine is more reliable AND I still have access to tools IF for some reason I had a problem. I pretty much know what's wrong with most Chevys that if I had to buy one it would just be the old K5 or the newer gen corvettes. Even the trusty old Silverados have a problem, at 75K miles the fuel pump goes out. *sighs* If only Toyota had an automotive class nearby then I wouldnt for GM.
Old 01-14-2005, 11:19 PM
NathanBERG's Avatar
It's is a 1996 v6 3.8 I will look into the intake gaskets. Thanks for all your help!
Well I can't fit much meat on it, but I do have a limited slip diff! LOL
Thanks guys!
