Idler Arm
Old 07-16-2004, 11:43 AM
az4x4runner's Avatar
Idler Arm
Is a pickle fork required to remove the idler arm, or have any of you successfully done it without?
Old 07-16-2004, 11:48 AM
Brendan's Avatar
pickle fork or tie rod puller, ya. i'm sure it could be done without one, but it's just so much easier with it. do the job properly and it'll save you time and sanity in the long run.
Old 07-16-2004, 11:51 AM
AgRunner06's Avatar
You can go rent one and then get a full refund when you are finished using it. Just put it on the credit card.
Old 07-16-2004, 11:55 AM
dusty98's Avatar
I just did mine this weekend with a tie rod puller and it was really easy. Slide it on, tighten it down and it pops right out.
Tie rod pullers are around $9 at most auto parts stores. Best $9 tool I've used.
Old 07-16-2004, 11:58 AM
Yeah.. that's for sure, I tried to remove my steering stabilizer without a pickle fork once...
Cool, I'll check out AutoZone or something. But if they are really only like $9 or so, maybe I should just buy one.
Thanks.
Old 07-16-2004, 12:01 PM
dusty98's Avatar
Thanks.
I got mine at a local Harbor Freight tools store. I wasn't sure the quality, but it looked the same as everyone else's in that price range. I used it to remove my idler arm, and my inner/outer tie rods so I got my money's worth from it.
Right tools make the job much more enjoyable.
Have fun!
Old 07-16-2004, 12:09 PM
Have fun!
Very true, I always enjoy working on my truck anyway.
Old 07-17-2004, 07:01 PM
jimbo74's Avatar
i borrowed a pitman are puller set from a cowrker when i lifted my truck... not only can it do pitman arms, but idler arms, tierod ends, and balljoints.....
Old 07-17-2004, 07:58 PM
Cebby's Avatar
You might want to add one of these:
I just put one of these on yesterday after I had my new idler installed. Took all of 10 minutes. (Downey Idler Arm Brace)
Old 07-18-2004, 12:09 AM
I think I may do that. I went and got a tierod puller today for $9, sure did make things easy.
Old 07-18-2004, 05:09 PM
Fink's Avatar
Cebby-
Where'd you get the brace from? That looks like it would be a worth while thing to do...I just had my new arm installed about a month ago...maybe less.
Fink
Old 07-18-2004, 05:12 PM
jimbo74's Avatar
fink... its a downey product... under $50
Old 07-18-2004, 05:43 PM
Co-Founder/Administrator
Staff
Corey's Avatar
Folk's, be sure to check out the Tech section.
I just got Mike's Downey idler arm write-up put up in the Tech section that he submitted tonight.
I think I will do this mod at a later date.
Old 07-19-2004, 10:54 PM
Well my steering seems nice and tight now. Unfortunately I still have my 60-70mph vibration .
I'm thinking it's a rim now, but noone's ever said anything all the times I've had them balanced... oh well, at least I don't go above 60 around here often .
ladybugRC
458
08-21-2020 10:41 AM
ktm192k
10-01-2015 08:47 AM
JookUpVandetti
09-30-2015 08:58 AM
tylermx71
09-29-2015 08:49 PM
crash813
09-27-2015 07:15 AM
Quick Reply: Idler Arm
