| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Idle spped issue
#2 (permalink) |
Sounds like the choke needs to be replaced.
An electronic choke is inexpensive and will resolve the issue of high idle too long. EDIT: There is a kick down circuit that is linked to the throttle cable cam. The cam has a screw that can be moved back and forth to adjust idle. Follow the throttle cable into the carb and you will see the cam, the kick down circuit, and idle adjustment screw. Last edited by amusement; 12-19-2003 at 04:10 PM. |
#3 (permalink) |
So I porbably need the shop maual for the procedure?
#4 (permalink) |
Check the voltage meter on the idle control sensor, and don't forget to check the main computer for any error codes. I had the same problem and I found that the sensor was bad; probably cost me 150 bones but will fix the idleing.
M |
#5 (permalink) |
Maverick the 81 22R is a non-computerized carberator setup.
No throtle sensor either.
#6 (permalink) |
Here's the deal.....I can't get the choke replaced without buying a $50 carb rebuild kit. So is ther any cheaper fix to this problem which is at worst annoying?
#7 (permalink) |
If the choke is a mechanical type then it will be necessary to by the rebuild kit. However, there is always the junk yard
.I might same the same for electronic chokes. Try some carberator cleaner. Last edited by amusement; 01-01-2004 at 08:53 PM. |
| Tags |
| 22r, choke, engine, toyota, unstick |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Idle Issue | JEBSR5 | 86-95 Trucks & 4Runners | 25 | 03-16-2007 06:05 PM |
| Idle issue | Sonofmayhem | 86-95 Trucks & 4Runners | 40 | 02-05-2007 06:50 PM |
| 22RE Idle Issue | blb | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 01-02-2006 02:32 PM |
| 22RE idle issue? | dave151 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 10-24-2005 12:48 PM |
| idle issue | jayson161 | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 12-13-2004 08:57 PM |
