Idle dampner help???
Old 04-15-2003, 06:33 AM
PirateFins's Avatar
Unhappy Idle dampner help???
This is on a 22RE. The part, I think you call it the idle dampner, with the spring that when you let off the accel pedal catches the throttle and brings it down to idle slowly, seems to be sticking. I have tried to clean it, lube it while still on the truck. Has anyone else had this problem? Do I need to remove it and clean it, and if so what is the best way? If it can't be cleaned, where should I get a new one from? Last but not least what is the correct name for that part. Right now it is not letting the truck come back down to true idle, it is holding it up way to high (not sure how high I don't have a tach).
Thanks for the help,
Fins
Old 04-15-2003, 06:46 AM
CTB
CTB's Avatar
For some reason, I have stuck in my mind that that part is called the dashpot...but I may be way off on this one!!!
Old 04-15-2003, 07:22 AM
Arnold's Avatar
Yup, sounds like the dashpot. Cleaned mine once and eventually threw it away.
Blamalam
03-12-2022 07:34 AM
Marsheen
02-17-2016 12:29 PM
GrimWolf
08-28-2015 03:36 AM
noosh
08-21-2015 03:49 AM
Sarcazmo
08-15-2015 08:22 PM
Quick Reply: Idle dampner help???
