i went 87!
yep, no need for anything higher then 87 on a 3.0 v6 with stock compression. These motors run a fairly low compression ( 9:1?) so no need for the extra octane. In fact you should use the lowest octane you can without pinging because the higher octane fuels take longer to burn.
Originally Posted by Bumpin' Yota
hehehe unless your 3.0 has carbon buildups from sheer age and now pings on anything less than 93 octane...even with the timing set back to 10* BTDC... *sigh* I need a 600CBRR so I can get 50mpg and run 12s on the track...
the truck with the 87 is sitting at home today.
I wonder if engines sold across the ocean are different because we only have 95 and 98 octane gas around here and recently i filled her up with some bad gas and it pinged like a !$#&%$#". And yes 1liter of 95 gasoline here costs 1.33$
87 has consistently been 2.43-2.47 here.
today i drove by the station and its... 2.68!
so i went to the black hole that is so random here... its a citgo station thats full service... for 2.48!
so random.
so random.
"unless your 3.0 has carbon buildups from sheer age and now pings on anything less than 93 octane..."
bumpin': just curious if you've tried any additives to remove some of that carbon...
