I need some 3.4 vacuum part pictures
I'm doing a 3.4 swap into my '94 4 Runner. I have a very valuable set of instructions, but I'm limited when it comes to vacuum lines. Could someone please post or send me pictures of the following on your 3.4? It would be greatly appreciated. If you do send or post pictues, be sure to label what each piece is. Thank you very much in advance. I'll get this thing done some day
Vapor pressure VSV
Vapor Pressure sensor
Purge VSV
Air flow meter
Vapor pressure VSV
Purge VSV
Air flow meter
http://aarc.epnet.com/application/93...MENDATIONS.htm
If you do a search in there you should be able to solve all your problems.
Avenged
07-09-2015 07:55 AM
