I need brake bleeding input please.... - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-17-2006, 07:55 PM   #1 (permalink)
Arron's Avatar
Send a message via MSN to Arron
Just finished new rear seals ( not to bad f a job if i say so myself, thanks to help from here ). So while i had the tires off i bleed ( blead past tense? ) the brake lines. Got the wife to pump a few times, and some fluid trickled out... i didn’t think she was pumping to hard hence the trickle... Anyhow when i got her off the blocks and all, she needed some fluid, as in the reservoir was empty. It was sitting for a few days on blocks while i got a dealer to press in the new parts, caped of as best i could, and a little fluid leaked. I had a tray under it, and nowhere close to the reservoir leaked out, maybe 1/10th.
So i got the reservoir filled up, and the brakes are still very soft. Could it be possible that the other wheels leaked out threw the one that was off, will i have to bleed all 4? I was planning on re-bleeding that one that was apart but thought i should get a little input b4 i try again.
Thanks
__________________
Arron
Arron is offline
Old 08-17-2006, 08:07 PM   #2 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
If you drained the reservoir, you will have to bleed the master cylinder, then the brakes again, starting at pass rear, driver rear, pass front then the driver front. If you are unsure how to bleed brakes properly, lots of 411 on the net about it.
waskillywabbit is offline
Old 08-17-2006, 08:10 PM   #3 (permalink)
Spanky's Avatar
Send a message via MSN to Spanky Send a message via Yahoo to Spanky
wow i had to read that a few times and i still do not know what you are asking!
__________________
1992 Toyota Truck 22re 5 Spd (194K and going!)
Magnaflow Highflow Cat
Flowmaster 40 Series Muffler
2.25" Pipes
K&N Air Filter
Airbox Mod, AFM Mod,
2" Body Lift
BFG All Terrain 31x10.50's
American Racing "Chamber" Wheels 15x8
Spanky is offline
Old 08-17-2006, 08:16 PM   #4 (permalink)
Arron's Avatar
oh my.... bummer..... how do i bleed the master cylinder?? sounds like a mess, maybe ill get a local brake shop to bleed it for me.
__________________
Arron
Arron is offline
Old 08-17-2006, 08:22 PM   #5 (permalink)
Spanky's Avatar
i needed mine bleed, didnt have a bleeder so i took it to midas and had it done for like $70 bucks... coulda bought one and done it myself for that price... and have owned a brake bleeder!
__________________
2.25" Pipes
K&N Air Filter
2" Body Lift
Spanky is offline
Old 08-17-2006, 08:27 PM   #6 (permalink)
Arron's Avatar
just need a clear rubber hose anyhow, and a friend to pump it. Sites say this is most effective, as well a gravity meathod.... Anyhow ive seen shops do this with pumping the brakes, very quick and simple job, for 70$ ill give it a try myself, just no idea how to bleed the master cylinder yet.
__________________
Arron
Arron is offline
Old 08-17-2006, 08:33 PM   #7 (permalink)
Spanky's Avatar
BTW. . . . your avatar is pretty damn funny! haha
__________________
2.25" Pipes
K&N Air Filter
2" Body Lift
Spanky is offline
Old 08-17-2006, 08:38 PM   #8 (permalink)
wjwerdna's Avatar
Send a message via AIM to wjwerdna
(bled = past tense of bleed or bleeding )
__________________
Andrew J W = WJwerdnA '99 4Runner SR5
- Pioneer MP3/IPod w/Infinity all around - lifted 2.5-3in susp. - 33's to fill the gap - sliders - ISR & Deckplate, yada yada - Satoshi -
AIM:wjwerdna
YotaTech Profile Custom Bumper Link
for sale:
??? Nothing?
wjwerdna is offline
Old 08-17-2006, 09:19 PM   #9 (permalink)
Spanky's Avatar
Quote:
haha :pat:
__________________
2.25" Pipes
K&N Air Filter
2" Body Lift
Spanky is offline
Old 08-18-2006, 04:49 AM   #10 (permalink)
Arron's Avatar
Thanks, my spell check was of no help for bleed. bleeding and bled. I have looked around some with no luck finding a post on bleeding the master cylinder for a 4rnr. Anyone know of a tech writeup or a link or something?
I love the avatar as well, there are many meanings to it, the dirty guys in here will think one thing...... I hope its a ok avatar!
__________________
Arron
Arron is offline
Old 08-18-2006, 02:39 PM   #11 (permalink)
Arron's Avatar
Ok done some reading and searching. Best info i could find is http://www.4x4wire.com/toyota/mainte...chmaintenance/ . Dont look so bad i guess. By bleeding the slave cylinder, will it bleed the master cylinder as well, or is there a seperate process for that? I looked on the master and there is no bleed nipple, just 2 brake leads coming off, and a third hole with a nut in it. My shop book only has how to purge the master while its on a bench, not while installed.
Can someone shed some light on the master cylinder for me, to make sure i do it right? Thanks.
__________________
Arron
Arron is offline
Old 08-18-2006, 03:27 PM   #12 (permalink)
CyMoN's Avatar
keep it filled up while bleeding the brakes i did mine last week also it will help to use a hand held vac pump 30$ at auto zone also dose not hurt to remove you bleeder nips and put some teflon tape on them, you will get a better seal and no air will come in while you have a vac on the line,the most important thing is to keep the res full at all times and if you are at this point of bleeding your brakes it is best to flush them ,brake fluid draws water in over time so when it gets cold out you can get ice in your brakes also at that time you might want to rebuild the cylinders if the pistons are still in good shape,a rebuild kit costs around 10$ to 15$ at NAPA they will not have them in stock but it only takes a few days for them to come in on order.
when i rebuilt my brakes there was a lot of crud in them now the fluid is clear as glass and i can stop alot better now, my brakes lock up again if i have to stomp on them.
on a side note i had bought some carbon metallic pads paid 50$ for them had them for a month on the truck rebuilt the cyliners and still had stopping problems bought some none carbon metallic and they worked a whole lot better.
good luck
__________________
my rigs
89 4runner
1989 4runner v6 5 speed everything factory +4susplift running bfg 31s and a aux gas tank and more aux lights than needed
86 pickup
1986 stock pickup 22r 31.10 BFG ATs flatbed
a sad day for the 4runner
"One moment of patience may ward off great disaster. One moment of impatience may ruin a whole life."
CyMoN is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Brake Bleeding Crazychopstick 95.5-2004 Tacomas & 96-2002 4Runners 2 06-09-2007 01:19 PM
My brake bleeding method dirtykaw 86-95 Trucks & 4Runners 8 04-15-2006 07:17 AM
Brake Bleeding? timk2915 95.5-2004 Tacomas & 96-2002 4Runners 2 10-11-2005 05:57 PM
Brake Bleeding? The Answer? AKennedy87 Maintenance & Repair Archives 14 05-11-2005 05:36 PM
Rav4 brake bleeding nhyota 95.5-2004 Tacomas & 96-2002 4Runners 7 12-28-2004 08:57 AM
2009 InternetBrands, Inc.
