I'm flaked, but synthetic . . . - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-19-2004, 06:41 PM   #1 (permalink)
4RunnerFever's Avatar
Send a message via AIM to 4RunnerFever Send a message via Yahoo to 4RunnerFever
Question I'm flaked, but synthetic . . .
Ok . . I changed the entire transmission fluid to Amsoil over the weekend and it was a messy affair. I did the pan fluid, new filter, and then flushed the entire system with 16 quarts.
Then, I managed to read the level wrong and drove about 10 miles without sufficient fluid. Lots of slipping and hesitation.
So now I've got the level right and everything works great (even better than before) but I've got metal flakes in the fluid. They are very small, but visible. Is the transmission doomed? I switched to synthetic to extend the life of the tranny, but now I think I might have killed it. The fluid doesn't smell burnt and is still bright red.
I went ahead and drained the pan again, but would it be worth it to change all the fluid again? or is it a lost cause?
__________________
2004 Tacoma Double Cab, TRD Off-Road, PIAA fogs, ARE Shell, Yakima, etc. 4RunnerFever
_______
GBNF: 1998-3rd Gen-4Runner, SR5, 4WD, TRD Supercharger, TRD Cat-Back, 3-inch Revtek Suspension Lift, 285/75-16 Revos, 4Crawler Offroad 1" body lift, Sonoran Trac Bar, Hayden Cooler, Hood Scoop, 'Outback' Mod, Optima 34R, Amsoil, Yakima, PIAA, etc. Sold to Mastacox.
4RunnerFever is offline
Old 07-19-2004, 06:47 PM   #2 (permalink)
shazaam's Avatar
Send a message via MSN to shazaam
remove your hood, and exchange it for mine .. and I think you'll be fine.
__________________
Experience is a hard teacher because she gives the test first, and the lesson afterwards.
<-- the artist formerly known as sdastg1
shazaam is offline
Old 07-19-2004, 06:50 PM   #3 (permalink)
If your hood will save my tranny - its yours bro
__________________
_______
Old 07-19-2004, 06:54 PM   #4 (permalink)
shazaam's Avatar
pm transdude he the transmission guy on this board .. very knowlegable (sp?) and very helpful. He actually has his number in his sig as well I think so you can call him.
Also Aamco offers a $99 complete power trans flush .. it might be worth it, if for nothing else then just piece of mind.
__________________
shazaam is offline
Old 07-19-2004, 06:57 PM   #5 (permalink)
Thanks for the tip sdastg1. I'm hoping things will be ok long term.
__________________
_______
Old 07-20-2004, 04:57 AM   #6 (permalink)
Bump . . .
Anyone else care to help me out with their insights/experience. I'd greatly appreciate it.
__________________
_______
Old 07-20-2004, 06:27 AM   #7 (permalink)
EDGE's Avatar
Send a message via AIM to EDGE
Thats normal metal in the pan, I've seen cars drain silver fluid, if it has not been touched for the 1st 15-30k then that all the breakin stuff but in general thats how transmissions are
__________________
2003 ES300
2003 V8 LTD 4Runner
2006 Nissan Maxima SE
EDGE is offline
Old 07-20-2004, 08:04 AM   #8 (permalink)
WolfpackTLC's Avatar
Send a message via AIM to WolfpackTLC
Metal flakes, no matter how small, are obviously wear... I'd do a complete drain and flush, then replace the filter.... I doubt it'd hurt much, but it's a safe bet to do so anyway. Big chunks of metal are obviously VERY bad.
__________________
1995 Land Cruiser -ARB'd, OME'D, Slee'd, Warn'd, lifted, locked, dented, WHEELED.
WolfpackTLC is offline
Old 07-20-2004, 01:21 PM   #9 (permalink)
These are really tiny particles and they are just here and there on the dip stick. What do you think about waiting a year and then changing the whole thing again. That Amsoil ATF is big dollars.
__________________
_______
Old 07-20-2004, 01:56 PM   #10 (permalink)
Guest
4RUNR's Avatar
Fix it till it's broken camp of thought, ehh?
Drop some SeaFoam in there. Then report back to us where the smoking was coming from.
4RUNR is offline
Old 07-20-2004, 02:41 PM   #11 (permalink)
MvCrash's Avatar
Greetings,
You can filter the oil depending on how small the particles are.
MvCrash is offline
Old 07-20-2004, 02:54 PM   #12 (permalink)
MvCrash - do you think the new filter inside the pan will take care of the small particles?
4RUNR - I think you may be right. Perhaps I'm stressing too much about this. You're saying - let it be?
__________________
_______
Old 07-20-2004, 03:04 PM   #13 (permalink)
colsoncj's Avatar
Send a message via AIM to colsoncj
it sounds like when you changed the fluid you disturbed what might have settled to the bottom... When you had the pan off did you clean the bottom of it, and did it have a magnet down there?
__________________
Cory
Eastern OK, Western/Northern AR, Southeastern KS, or Southern MO area: OZARKS 4ROC Click Here
04 Dodge 2500 Cummins - DD/Tow Rig
02 Z06 Corvette - Weekender
94 FZJ80 - Wheelin Rig. Build in progress: http://ttora.com/forum/showthread.php?t=129727
72 Buick GS - i.e. the project that will never get done.
colsoncj is offline
Old 07-20-2004, 03:07 PM   #14 (permalink)
Guest
4RUNR's Avatar
I'm not licensed to say anything here And certainly not going to pretend to know everything about transmissions in 3rd gen 4Runners.
But my bet is, if your manual says to drain and refill with Toyota fluids every so and so miles, doing that (mixed in with sensible driving habits) will net you no less trouble free miles than performing some voodoo rituals that you heard online.
4RUNR is offline
Old 07-20-2004, 03:53 PM   #15 (permalink)
I did clean the pan and the magnets, but there could have been particles in the old fluid up in the transmission itself I suppose.
4RUNR - I know what you mean about learning stuff on line. It is hard to know what to believe sometimes. North Pole aye? Cool.
__________________
_______
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Synthetic or Not! Bigvick General Vehicle Related Topics (Non Year Related) 32 05-26-2006 09:50 PM
Changing to synthetic timk2915 95.5-2004 Tacomas & 96-2002 4Runners 1 05-25-2005 01:03 PM
synthetic? Tokez420 95.5-2004 Tacomas & 96-2002 4Runners 3 05-19-2004 04:13 PM
I'm Synthetic and more!!! ugadawg95 95.5-2004 Tacomas & 96-2002 4Runners 5 11-18-2003 10:57 AM
Synthetic or not!!!! obxfishn 95.5-2004 Tacomas & 96-2002 4Runners 8 03-17-2003 12:17 AM
2009 InternetBrands, Inc.
