I cannot program my new alarm remote! help - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-02-2004, 11:25 AM   #1 (permalink)
payyourtoll's Avatar
I bought a new remote for my rs3000 alarm off ebay. I cannot get it programmed following the easy steps here:
http://www.4runners.org/articles/rs3000
I get stuck at the point where holding down the green reset button on the brain will trigger the red alarm light to stay on, mine stays on for ~3-4 seconds only, and then goes out. The remote top button does nothing to this light when pushed.
Anyone had this problem? thanks
__________________
Rob
payyourtoll is offline
Old 11-04-2004, 01:49 PM   #2 (permalink)
Yesterday I tried clearing all remote programming from the brain, that would not even work as intended. I will post details of that if I see any indication that anyone here knows about the RS3000. I really think that the unit is toast.
I need some help
__________________
Rob
Old 11-05-2004, 08:56 AM   #3 (permalink)
Del
Del's Avatar
I have a different system (DEI) but here's what I did (I've had to reprogram it about 5 times) :
1. Turn the truck to "On" position (don't start it)
2. Within 15 seconds, push and hold the valet switch until you hear a chirp (if no chirp is heard,
ignore the rest of this)
3. Push the first button you want to program. You should hear another "chirp" which means it's programmed.
4. Now take the keys out and test the first button. Did it do what you wanted? If not, repeat #2 but instead of pushing the valet button once, push twice and hold the second time, again until there's a chirp. Repeat #3 to program the remote. -edit- My alarm has 10 "programs" it can run, so it takes a while to figure out which ones to use (I have a 2 button remote).
Repeat steps 2, 3, 4 until all your buttons are doing what you want them to do (ie: lock/unlock, autostart, etc...) Again, I have DEI but I figured you might want to just give this a shot. Good luck!
__________________
2003 Subaru WRX
______________________________________________
http://www.myspace.com/del_vecchio
Del is offline
Tags
03, 2002, alarm, button, dei, press, program, programing, programming, remote, reprogram, startdoors, valet, wrx, xpress
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
program a new remote? deputydawg Alarm Systems 3 09-06-2007 09:15 PM
How to install remote Alarm trumso01 Alarm Systems 0 07-19-2007 11:29 AM
remote start+alarm YodaPala Alarm Systems 7 02-17-2007 03:57 PM
Door/alarm remote krue 95.5-2004 Tacomas & 96-2002 4Runners 5 03-03-2006 01:21 PM
program new security system remote jimber00 95.5-2004 Tacomas & 96-2002 4Runners 1 10-20-2002 03:56 PM
2009 InternetBrands, Inc.
