humming alternator?
Old 02-27-2003, 07:04 PM
momo76's Avatar
humming alternator?
my truck has been doing this wierd humming noise from the engine bay. My Toyota tech says it is coming from the alternator. Has anyone experienced this before and does it mean the alt is about to go?
Old 02-28-2003, 06:32 AM
CTB
CTB's Avatar
Do you hear the humming on the inside of the truck or only when you are listening under the hood? If you are only under the hood and hear it, could the pulley on the alternator have a bad bearing? Just a guess. If you hear it on the inside of your rig, could you maybe have a ground loop ( I think that is what it's called) caused by a larger stereo install? Just a couple guess to try out.
Old 02-28-2003, 10:32 AM
Hbum's Avatar
In my experience a hum or groan from under the hood is either low fluid in the power steering or a bad diode in the alternator. The sound is similar. Check the fluid in the PS, if OK, pull alternator and take to a rebuild shop and ask them to check it out. I suppose it is possible it is an alternator bearing.
Let us know how this plays out.
shooter86314
01-07-2016 07:05 AM
Chicken12
10-14-2015 03:54 PM
JPV
09-28-2015 03:15 PM
fountain
09-28-2015 03:04 AM
SCZIG
09-20-2015 09:00 AM
Quick Reply: humming alternator?
