how remove pin stripe
Old 04-23-2008, 12:25 PM
fr3533's Avatar
whats the best way to remove pin strips
Old 04-23-2008, 12:31 PM
shaw_j's Avatar
Some sort of heat producer such as a heat gun (i've even heard of blow driers working), and a razor blade.
be very careful with the razor blade if you are concerned about damaging the paint
Old 04-23-2008, 04:02 PM
my014runner's Avatar
I have work lamps in the garage that I place about 14-20 inches a way and you can do about 3 feet every few minutes and it will almost slide right off... don't leave the lamps in one spot for too long though.
Old 04-23-2008, 04:25 PM
xcmountain80's Avatar
Well trees tend to pin stripe my truck,,, so in theory if you could align said tree with pin stripe you too may remove one with the other.
Aaron
Old 04-23-2008, 05:14 PM
CyMoN's Avatar
2500 pis power washer works real good just don't hold it too close or it can remove the paint.
Old 04-23-2008, 05:20 PM
cmflossin's Avatar
i used a blow dryer and some goo-gone. worked like a charm.
Old 04-23-2008, 07:57 PM
Cxrazy's Avatar
Hot ass Halogen Lamp + Peel it off + goof off to get the stuff off.
Your golden. Just take your time peeling and make sure you get the glue off.
Old 04-23-2008, 09:12 PM
Steveh29's Avatar
I've said it before and I'll say it again. 3M Woodgrain And Stripe Remover does wonders on this stuff.
Sean McAuley
9
11-08-2015 12:26 PM
JAmdor3
08-11-2015 10:53 AM
TJWilly
07-31-2015 02:05 PM
msane99
07-17-2015 10:13 AM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: how remove pin stripe
