how to remove antenna in 2002 sport?
If the teeth broke or the cable broke, you need to get to the antenna from under the fender liner. Once you pull the liner back, you can get in there and remove the motor cover and take out any broken pieces. Once you get the pieces out, put the cover back on, and you can install the new mast/cable. Make sure you remove the upper nut and take the pieces out of the antenna tube.
http://forum.ih8mud.com/95-gen-toyot...placement.html
You can also find this info by using our handy dandy search feature
justdifferentials
Just Differentials
08-15-2015 05:25 PM
