How many trim packers can I use?
Hey, all-
Yesterday, I went out and remeasured all four corners. The driver side sits lower than the passenger side. I know this is common with lifts, but, these are Tundra coils. I thought for sure the Tundra coils would solve that issue.
I'm using Tundra coils and 1" Cornfed spacers. The driver's side sits 1" lower than the passenger's side. Can I use OME trim packers on a Cornfed spacer? How many can I safely use? If they are 5mm each, I'll need 4 to level 'er out.
Originally Posted by HaveBlue
Hey, all-
I know this thread is alittle old, but here is my scenerio... if I have a one inch cornfed spacer up front and one inch spacer in the rear....and I get a slight rear sag due to a safari rack/spare tire could I use a trim packer to add alittle height on the cornfed spacer in the rear to achieve a level stance or a slight rake ???
Thanks.
Thanks.
kawazx636
10-06-2021 03:03 PM
matmattmatthew
10
02-09-2021 04:15 PM
