How many bolts for Differential Drop?
I've loosened the 2 big bolts the spacers are supposed to sit on top of. The differential doesn't seem to have dropped, are there any more bolts holding it in place?
did you just loosen it? or remove the whole bolt? youre supposed to remove the nut, pull the bolt completely, then it should drop. Ensure youve got a method of support like a floor jack. Slip in the spacers, put in new bolts, and torque er down...
I got the bolts off but you have to really pry the differential down to get the spacers in there and when you do, you are now trying to put a long bolt through somewhat of angle...is this right?
Yup, the bolts go through at an angle, sonoransteel has a tapered spacer, but the bolts are still at an angle.
http://www.sonoransteel.com/store_ta...diff_drop.html
Blamalam
03-12-2022 07:34 AM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
ripp96
07-31-2015 11:14 AM
