How the heck do you remove the trans pan? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-14-2007, 04:39 PM   #1 (permalink)
bmwpower's Avatar
It's stuck on there pretty good with some sort of red factory sealant. The shop manual says to use some special tool with a blade...don't have it.
Help! Sitting under my truck trying to figure out what to do next.
Thanks!
__________________
97 4Runner SR5 4X4 (sold) | 04 Sienna LE AWD | 99 M3 | 90 535i | 89 325is
bmwpower is offline
Old 04-14-2007, 04:47 PM   #2 (permalink)
Greedy's Avatar
Just work a screwdriver or paint scraper around the edge and gradually pull the pan away from the tranny. Toyota uses the red sealant instead of a gasket on our trans pans (and oil pans) so before you reinstall it you will need to clean off both surfaces anyways.
__________________
- 1999 4Runner Highlander Edition
- Turbonetics BB T3/TO4E TURBO
- URD Fueling
- 3 Inch Turboback Exhaust
- 16x8 Volk TE37X
- OME Lift
Greedy is offline
Old 04-14-2007, 04:52 PM   #3 (permalink)
bmwpower's Avatar
Oh boy. I'd to hate use a screwdriver the flange like that, but I will give it a try.
OK to use the Right Stuff to reseal the pan?
__________________
bmwpower is offline
Old 04-14-2007, 06:31 PM   #4 (permalink)
bmwpower's Avatar
Ok... got it off with the help of a deadblow, razor and a screwdriver...
Now how do I maneuver it out of the way??!?! I can't seem to figure out how to drop the pan out..
THanks!
__________________
bmwpower is offline
Old 04-14-2007, 06:43 PM   #5 (permalink)
bmwpower's Avatar
Do I have to drop the front swaybar??
__________________
bmwpower is offline
Old 04-14-2007, 06:50 PM   #6 (permalink)
4banginRunner's Avatar
i had to drop the swaybar to get the tranny pan off my 90 4Runner if that helps
__________________
87 Toyota 4Runner
22RE--5spd swap (W56)--4.56s--BJ spacers--Pro Comp Stage II 4" bracket lift--63" Chevys w/2" blocks--40 series--late style steering box swap--BudBuilt Dual Case X-member--V6 calipers--32s--MC rear bumper--SAS parts collecting time...
79 Toyota Longbed 4x4
Frame-off Resto time.
04 GMC Sierra 1500
the DD
4banginRunner is offline
Old 04-14-2007, 06:55 PM   #7 (permalink)
CyMoN's Avatar
guess I am a little late a 4 to 6 inch putty knife works well for breaking the seal as well
__________________
my rigs
89 4runner
1989 4runner v6 5 speed everything factory +4susplift running bfg 31s and a aux gas tank and more aux lights than needed
86 pickup
1986 stock pickup 22r 31.10 BFG ATs flatbed
a sad day for the 4runner
"One moment of patience may ward off great disaster. One moment of impatience may ruin a whole life."
CyMoN is offline
Old 04-14-2007, 07:00 PM   #8 (permalink)
bmwpower's Avatar
Ok....
I think I got it....
You need to drop the truck to the ground so the swaybar is preloaded. With the swaybar tweaked a little bit, you have enough room to lower the pan.
Thankfully these trucks are fairly high off the ground, so I can sneak under there and do what I have to do.
Thanks guys!!
__________________
bmwpower is offline
Old 04-14-2007, 07:16 PM   #9 (permalink)
Mason Dixon's Avatar
Send a message via AIM to Mason Dixon
http://yotatech.com/showthread.php?t=106605
__________________
http://www.sectalk.com/images/graphi...ds/alabama.gif
2000 4Runner SR5 4x4 Sport
Mason Dixon is offline
Old 04-15-2007, 08:42 AM   #10 (permalink)
bmwpower's Avatar
Don't know how I missed that thread, I must have looked for 30 minutes or more for something. Thanks!
CORRECTION (on my previous post)...you have to remove the swaybar to get the pan BACK UP...unless you want sealant all over your filter/screen (ask me how I know).
So after I had everything ready to go, I get under the truck on the ground to find out that it's not going to go back on like the way it came off. I had to lift the truck again and remove the swaybar....BROKE ONE OF THE BRACKETS in the process. You should have heard the curses flying. Not fun when you're sealant is in the process of drying up.
So I ended up having to drill out the remained of the stud on the broken bracket and put a regular bolt on instead. That should hold now until I get a new bracket and bushings - boy were they shot.
__________________
bmwpower is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
PLEASE HELP!Must remove fuse to remove ignition key randyman_ar General Electrical & Lighting Related Topics 3 05-01-2006 08:32 PM
Quick How To Remove Oil Pan 4Hummer 95.5-2004 Tacomas & 96-2002 4Runners 8 11-14-2005 01:50 PM
How hard would it be to remove/reinstall an auto. trans. on a '94 runner? gsxrguru 95.5-2004 Tacomas & 96-2002 4Runners 4 02-27-2005 06:19 PM
Remove Pan Rod Bar on 4Runner Scottz Offroad Tech 10 10-08-2004 05:39 PM
GRRRRR... Trans pan 22Ryota 95.5-2004 Tacomas & 96-2002 4Runners 4 08-22-2004 02:26 PM
2009 InternetBrands, Inc.
