How hard is it to replace the Timing Belt on a 3.4L ?
I am wondering how hard it is going to be to replace the timing belt on a 3.4L 2001 4Runner. I've heard it is much more involved than most projects. I am pretty mechanically inclined and think I could work through it with instructions though. Anyhow, has anybody done it? Is it one of those things that you would be much better off paying a mechanic to do? Your thoughts are appreciated...
i think you also need a SST for the crank pulley. theres a good writeup on it on 4X4 wire i think. it shows you how to make one yourself.
personally, id pay a shop to do it. that way, if something goes catastrophically wrong, it wont be anyones fault but...theirs!
other things like suspension, brakes, etc simple nuts n bolts i'd do myself. things that dont require SST's and precise measuring tools.
another thing, is it neccessary to really move anything? I always assumed I could get away with removing components, slip off old, put on new, no difficulty... or is this not true, the manual mentions all sorts of having to re-line-up stuff, or maybe I am just making it seem more complicated? Also, to help with my, and OP's question, are the other components, idler/tensioner a good idea to replace? or unnecessary? I have seen a few people list those as replacement items
see below for excerpts from repair manual =) [EDIT: FOR A 1999 - SR5]
[clickable]
[clickable]
it is a pretty in depth project, with good potential for not working right
Those are great links to the FSM.
I would always suggest replacing wear parts like water pump, bearings, etc etc. You dont want to have to tear it all down and do it again in 3 months if it could have been prevented by replacing a few parts now.
water pump I assumed, I guess the others are a good idea too
I agree about having a shop do it. I just had mine done this week at a shop that only works on Toyotas(not a dealership) and they waranteed all parts and work for 12 months or 12,000 miles.
They did the timing belt, water pump, thermostat, idler bearing, tensioner bearing and all new acc. belts for $577.00.
Well worth it to me.
Thanks for all of the input so far guys! Anybody happen to know exactly what SSTs (special service tools) will be needed. I feel like I could probably buy them for a decent price and then ebay them...
The following users liked this post:
Jesus is Lord (10-17-2020)
voiddweller
19
05-02-2016 09:10 PM
B. Graves
07-03-2015 04:10 AM
