How to get nut off 95 4x4 tacoma front hub
Old 11-21-2014, 03:47 PM
BigHoss_27's Avatar
Old 11-21-2014, 03:51 PM
JasonYota's Avatar
Spindle nut socket
Old 11-21-2014, 05:15 PM
BigHoss_27's Avatar
Do I have to take whole thing off as in tie rods and stuff to get to bearing
Old 11-21-2014, 05:44 PM
JasonYota's Avatar
I would say no but in not 100 percent, never done a Tacoma. Take the caliper off and remove the spindle nut and the rotor and hub should come off with the bearings inside
Old 11-21-2014, 06:30 PM
BigHoss_27's Avatar
Does the part the wheel bolt to come off or does the whole thing have to be took off from tie rods etc
Old 11-21-2014, 06:32 PM
BigHoss_27's Avatar
Sorry just saw post in guessing take special socket and take but off then remove and put new bearing in
Old 11-21-2014, 06:38 PM
JasonYota's Avatar
I'm sorry I know this is a forum but try and make readable sentences it's very difficult to comprehend what your trying to say.
Yes you need a spindle nut socket (they make many different kinds) to remove the spindle nut in the picture you posted.
Old 11-21-2014, 07:20 PM
BigHoss_27's Avatar
I need to replace bearing on inside some say you can't take that piece off with the six little marks in it (brass piece) and I seen others that have to take whole knuckle and all out
Old 11-21-2014, 09:01 PM
BigHoss_27's Avatar
This diagram shows locking nut on back side
Old 11-22-2014, 04:08 PM
rworegon's Avatar
The steering knuckle with axle hub attached must be removed from the vehicle as the bearing is pressed in. You deal with that nut on the backside after the knuckle assembly is off the rig.
Colington
03-08-2020 09:51 AM
Whatever123
09-30-2015 12:12 AM
redneck17
07-17-2015 07:44 PM
ItsJustD
07-07-2015 07:49 AM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: How to get nut off 95 4x4 tacoma front hub
