How do I make a 2wd look like a 4wd??? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 01-27-2005, 06:47 AM   #1
Innocent Fool's Avatar
A question for all you Totyota gurus out there
I've got a 91 2wd ext cab truck but I've always liked the look of the 4wd.
What do I need to change on my 2wd to make it look like the 4wd?
As far as I can tell it's the fenders, front turn signals, and grill. Is the box on the 2wd the same as the 4wd?
Also, how do I get my 2wd to ride the same hight as the stock 4wd?
I really like the ride of the 2wd and don't want to make it much harsher. Do I just need torsion bars and rear shackles or is it more involved than that?
I plan on using stock 4wd tire sizes
Please drop me a line and let me know
Thanks!
Innocent Fool is offline   Reply With Quote
Old 01-27-2005, 07:03 AM   #2
kyle_22r's Avatar
i think jimabema74 is the authority on this.
the fenders are different, not sure about the box. the box might have different fender flares but it could be different...if all else fails you could cut the fenders.
however, if you mainly have looks in mind keeping your truck looking like a 2wd and putting bigger tires on it makes them look bigger than they really are, because of the smaller fender openings. i think with some lift you can probably run 30s or 31s.
kyle_22r is offline   Reply With Quote
Old 01-27-2005, 05:23 PM   #3
BeaterToyota's Avatar
Check out Fabtech.
BeaterToyota is offline   Reply With Quote
Old 01-27-2005, 07:26 PM   #4
Pretacopower's Avatar
Quote:
Originally Posted by BeaterToyota
Check out Fabtech.
and have your wallet and a friend's shoulder to cry on ready
Pretacopower is offline   Reply With Quote
Old 01-27-2005, 07:54 PM   #5
swimmer's Avatar
Add a transfer case and a front diff.
swimmer is offline   Reply With Quote
Old 01-27-2005, 08:00 PM   #6
04Tacoma4x4's Avatar
if i were you id send jimabema74 a pm or check out his truck, its a mid-late 80's (not sure of year) 2wd pickup that he has lifted and has 31x10.50 (stock 4wd size) tires on it, it looks really nice, he could tell you exactly what to do
04Tacoma4x4 is offline   Reply With Quote
Old 01-27-2005, 08:18 PM   #7
Adam F's Avatar
Sell your 2wd and buy a 4wd. Much easier, and quite possibly cheaper.
Adam F is offline   Reply With Quote
Old 01-27-2005, 08:56 PM   #8
Yamaha+Toyota=Fun's Avatar
buy a 4wd sticker.... all the american companys do it
Yamaha+Toyota=Fun is offline   Reply With Quote
Old 01-27-2005, 09:12 PM   #9
kyle_22r's Avatar
i beg to differ. 4x4s typically go for a lot more money than 2wds...doing a body lift will fit bigger tires easily.
Old 01-27-2005, 09:24 PM   #10
GregStevens's Avatar
Get some mudflaps that have 4WD imprinted on them.
GregStevens is offline   Reply With Quote
Old 01-28-2005, 05:07 PM   #11
mikedog's Avatar
You can get the Fabtec 3.5" 2wd lift kit with spacers for the wheels to lift the front. Or, you can use lift spindles like jimabena74 has. I assume using lift spindles will make front wheel spacers unnecessary, but lift spindles are more expensive than the Fabtec front susp. lift kits.
Lifting the back will be a problem though. At least it is for me. Whether to use re-arched lift springs, AAL's or longer shackles is really confusing. I guess it's a trial and error kind of thing. Mix and match sort of deal. However, when you start spending $$$, this can get very frustrating if you know what I mean. I still haven't received a definitive answer on how to best level out the truck with the 3.5" fabtec front susp. lift.
You'll probably need longer brake lines. Most places give you only (3) extended brake lines per kit. So, that means you have to purchase two brake line kits to get all four. Ain't that nice of them? You can go to the stealer and buy (4) clutch line hoses to use as extended brake lines, but that'll probably cost you way more than buying two aftermarket extended brake line kits. Finding (4) of them at the junkyard might be good choice if you're real cheap though.
You may want to upgrade the rear axle ratio if go to with larger diameter tires. Just going from P195/70R14's to LT 27" tires on the same rims made a HUGE impact in gearing on my 2wd truck. 4th gear is practically useless for passing at freeway speeds. I have a 4sp manual with 3.07 rear gears. 4th gear is more like a deep overdrive gear now. Lord knows how it would feel with 31's or larger on it.lol!
mikedog is offline   Reply With Quote
Old 01-28-2005, 06:29 PM   #12
kyle_22r's Avatar
huh? there's only 3 soft lines that need extending -- front calipers and the line that goes from the frame to the rear axle.
Old 01-28-2005, 08:07 PM   #13
mikedog's Avatar
Yeah, sorry about that....I forgot that the metal brake line for the rear drums snake over the rear axle to one flexible line. I must have been thinking about rear disc brakes or something.
I remember someone telling me you have to buy (2) aftermarket extended brake line kits to do one 2wd lift.
Also, make sure you modify the LSPV lever arm with a drop down bracket or bend it up when you lift it. If you don't, you'll have practically no proportioning to the rear brakes.
Old 01-28-2005, 08:48 PM   #14
You can do a SOA on the back.
But yeah, fenders, bed, grille, front lights, are all the body parts that are different.
Greg_Canada is offline   Reply With Quote
Old 03-09-2005, 09:57 PM   #15
jimbo74's Avatar
Quote:
here is my 4x2
jimbo74 is offline   Reply With Quote
Old 03-12-2005, 11:01 PM   #16
Ontos's Avatar
Why is it that nobody ever wants a 4WD to look like a 2WD?
Ontos is offline   Reply With Quote
Old 03-13-2005, 12:33 AM   #17
jimbo74's Avatar
a 4x4 to look like a 4x2? why? you lift a 4x2 to make it more capable offroad... there is no point in making a 4x4 less capable by lowering it......
88 Pickup Transmission Swap mskalmus 86-95 Trucks & 4Runners 6 03-21-2016 12:41 PM
WTB[PacSoWest]: Oil Dipstick Tube 1985 4wd Pickup adammtb Items Wanted 6 07-27-2015 12:57 PM
torque rear seal retainer 1990 2wd colasurdo Prerunner & All 2WD Rigs 0 07-16-2015 12:32 PM
What exhaust pipe do I need? hexrain Prerunner & All 2WD Rigs 4 07-12-2015 02:13 PM
NEED HELP! 4wd actuator Vacuum line! TokyoD23 95.5-2004 Tacomas & 96-2002 4Runners 4 07-12-2015 07:01 AM
Tags
2wd, 4wd, awd, bigger, cost, feel, ford, fwd, give, make, message, prform, tacoma, tires, toyota, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
