YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 10-20-2006, 04:56 PM   #1 (permalink)
jeremys73's Avatar
How bad do 285s rub w/no lift
I just got 285s on back and will be getting them on front next week (yes it looks a bit funny right now... hot rod style). My question is how bad will 285s rub with no lift. Will it be tolerable to drive on the streets until I can get a lift? or will it start ripping stuff off the truck????
__________________
3.4l | Auto | eLocker
jeremys73 is offline
Sponsored Links
To remove this ad, register today!
Old 10-20-2006, 05:02 PM   #2 (permalink)
Tacoclimber's Avatar
Just go straight.
You're probably gonna need to do some trimming to the fender walls, and possibly the outside trim, not to mention the upper A-arms...
I have a 2.75" lift on my Tacoma, with 285's and I'm rubbing the frame at full lock, and in the rear at full stuff. I'm planning at least a 1" bl to take care of it. You may wanna wait and do it right the first time...
__________________
CJ ...<><
03 DC TRD Tacoma 4wd with a bunch of junk.
Just wheel the stupid thing!!!
But do it responsibly, ok?
Tacoclimber is offline
Old 10-20-2006, 05:05 PM   #3 (permalink)
neliconcept's Avatar
go ahead and get a 2 inch bl to clear em if you dont wanna pay a lot.
otherwise break out the sawzall and have fun cuz its gonna be a LOOOOOT of trimming
neliconcept is offline
Old 10-20-2006, 05:13 PM   #4 (permalink)
rcars4life's Avatar
Send a message via MSN to rcars4life
Take lots of pictures of the chopping when you trim
__________________
Not my STI
'96 Limited 4runner
-ISR, Deckplate mod, Diff breather mod, upgraded headlight harness, TrueFlow
-comealong, 20' recovery strap, toolset, tireplugs, tirefixer/inflater, flashlights, warmclothes!
rcars4life is offline
Old 10-20-2006, 05:32 PM   #5 (permalink)
jeremys73's Avatar
arrrgggg.... So I won't be able to drive it if I get 285s on front w/o a lift???? I'll take some pics of it with it the way it is.... it looks like a Starsky & Hutch ride right now.... I love the way the 285s look though.
SO the thing is... I had two balding tires and had to get some new ones, so I went ahead and got the 285s on back and will get the 285s on front next check....
Would a small lift do the trick? Maybe some spacers up front... seriously... I just need it to be drivable on pavement for now... I don't care if it rubs a little bit for now...
__________________
Old 10-20-2006, 05:41 PM   #6 (permalink)
That was a mistake. Why did'nt you just get 265's? Now you are opening a can of worms.
You have to lift it or get the right size tires. Your best bet would to be just get the right size and sell the 285's if you cant afford to lift it right.
BeachRNR is offline
Old 10-20-2006, 06:08 PM   #7 (permalink)
d0ubledown's Avatar
Send a message via MSN to d0ubledown Send a message via Yahoo to d0ubledown
what wheels are you running them on? stockers or otherwise? i think some 285's rub a arms on stock wheels. my 285's rubbed on my running boards & fender flare trim WITH a 3" lift. i was on 8inchers though, and not stock 7's. why not try the backs up front and see what hits when you go lock to lock? if youre clear with the A arms & the frame rails you may be good to go. oh you might have to check the pinch weld area too...
go n get a 1 or 1.5" BL till you can get a proper lift in. good luck!
__________________
sonny
1998 4Runner LTD. Fabtech CO fronts, OME/Pro Comp rears, SS rear links, Revtek diff drop, oem elocker, ARB RD90, 4.88's, 315/75/16 MT/R's on FZJ-80's, Trail Gear sliders, ARB Prado Bar, 1.5" 4Crawler BL, Tundra Brakes, wabfab disco's, IPF's...satoshi'd deckplated & ISR'd.
SOLD!!!
new ride: 1997 FZJ80. ome/arb/bfg/etc.
when clinton lied..nobody died
d0ubledown is offline
Old 10-20-2006, 06:39 PM   #8 (permalink)
jeremys73's Avatar
good idea... I will try that. I'm on stockers BTW.
__________________
Old 10-20-2006, 07:25 PM   #9 (permalink)
AH64ID's Avatar
Send a message via MSN to AH64ID
Unless its a body lift of bracket lift they will fit just the same now as they do with the lift. Well, with the lift youll get a little more street clearance, but on the trail they will hit everywhere they hit now...
__________________
-John
'05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600 6 Spd, Pricol EGT and boost, 2" Level, Jake Brake, Muffler Delete, filtered, lubed and bypassed by Amsoil, Mag-Hytec Rear, Fast Coolers, Baldwin 7977, Smarty JR SW#1, Toyo 285's...
2003 SR5 4Runner, V6 4WD. 1" cornfed lift
Previous Toyota's '92 Red Truck NALA
Speed doesn't kill, its the sudden stop that hurts.
AH64ID is offline
Old 10-20-2006, 08:00 PM   #10 (permalink)
RunnerUp's Avatar
you are gonna rub like crazy... save your money up and buy a lift, you can get a good lift for around 650. otherwise your just going to destroy your new expensive tires and your wheel wells
__________________
Kyle
2002 4Runner - Lifted/Locked/Armored - 130k Miles
2007 4Runner V8 Sport Edition 4WD
Buy My Stuff!!!
MASTER CYLINDER 1" BORE - TG - $100
WESTIN BRUSH GUARD 99-02 4RUNNER - $200
STOCK 16" 5 SPOKES - LIMITED WHEELS - $400
96-02 Leather Seats (Perforated) - $500
Eclipse AVN2454 Navi Double Din - $500
RunnerUp is offline
Old 10-20-2006, 09:18 PM   #11 (permalink)
jeremys73's Avatar
I appreciate the knowledge. I'll search the body lifts because I love the 285s... I don't really run any hardcore trails but I occasionally (every weekend) have to yank a 5x10 trailer with a 700r and 200x up some pretty nasty climbs and muddy rutted out trails to get my quad to and fro... it's gotten pretty heavy throttled a few times with the stock tires
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
285s or 305s Localmotion Items Wanted 1 02-04-2007 08:37 AM
I need help to clear 285s for cheap Patsawasy 95.5-2004 Tacomas & 96-2002 4Runners 27 10-05-2006 11:12 PM
285s not fitting Stump1883 95.5-2004 Tacomas & 96-2002 4Runners 156 12-12-2005 03:55 PM
Finally Complete - OME lift, 285s, TJM Renegades Offroad Tech 26 10-09-2005 05:08 PM
285/75/16 MT/R will rub on 4th gen w/ lift Good Times 95.5-2004 Tacomas & 96-2002 4Runners 0 02-02-2004 10:38 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
