homemade rear coil spacers? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-05-2007, 01:46 PM   #1 (permalink)
I searched all over here and the net and have not come up with rear coil spacers less than an 1 1/2". I thought I saw a member here who had a homemade spacer lift kit, or am I mistaken? I am just looking for no more than one inch of rear lift to get a slight rake on my truck. The only thing I can think of is making my own. Anyone have an idea of what material to use?
__________________
'01 4Runner SR5 4x4
shiftMX is offline
Old 09-05-2007, 02:44 PM   #2 (permalink)
cornfed makes a 1" rear spacer. OME also has a 10mm trim packer. I think you can combine 2 packers to net 20mm. I may use an OME for my left rear wheel. I recently installed the 99 springs, and the left rear is a little low due to the weight of the gas tank.
johnw999 is offline
Old 09-05-2007, 02:54 PM   #3 (permalink)
I would like to do it for less than $100. I would buy new rear coils before I pay that much for spacers. I am just looking for a cheap temporary fix until I can get my lift and 285's. I thought about the OME trim packers, but 2 stacked will barely net .75". I would like a little more rake than that.
__________________
'01 4Runner SR5 4x4
shiftMX is offline
Old 09-05-2007, 03:06 PM   #4 (permalink)
frodin1's Avatar
I made a set of 4 for under $20. Order a small sheet of HDPE from Mcmastercarr. You can get pretty much any size and thickness you want. I went with half inch. A little cutting and sanding later I had four of them. I ended up giving the other set to another member on here. If you need any other info, let me know. By the way that .5" is just what I needed. Good luck!
__________________
Pioneer HU, Audiobahn 10.100watt Sub, Sirius, Cobra NWWXST CB W/ K40, Wolo Air horn, K&N FIPK,Tokico Trekmasters,Tundra TRDs, Revtec spacers w/extended studs,Energy bushings on steering rack /front swaybar,SS front diff. drop kit w/skid plate mod,OME 890 Rears with OEM LC Tokicos,Ebrake ext. bracket, BFG AT/KO's, ProComp 1078 Alloys, Magnaflow SS muffler, Hayden 1678 Tranny Cooler, 85watt Amber fogs, 7 Way R/V plugin.
frodin1 is offline
Old 09-05-2007, 08:02 PM   #5 (permalink)
Quote:
Can you give some detail on how you made them. Like what size sheet and what you used to cut them? I am gonna try this route. It is worth a shot for $20.
__________________
'01 4Runner SR5 4x4
shiftMX is offline
Old 09-06-2007, 02:52 PM   #6 (permalink)
Hey ShiftMX - what happened when you mixed the front 99 springs with the rear OME 906 springs? Were the rear springs too tall? Do you remember what measurements you had (ground to wheel well)? Thanks
johnw999 is offline
Old 09-06-2007, 03:28 PM   #7 (permalink)
frodin1's Avatar
I bought a 12x12 sheet from mcmaster-carr. I traced out the outside size, then used a compass to get the inside circle perfect. I used a jigsaw and cut out the inside first then the outside. It wasn't perfect but it sat nice and tight between the spring and the bumpstop. You could route or even melt a groove for the spring to rest in, but I didn't bother. The white in the pic is the spacer..
__________________
frodin1 is offline
Old 09-07-2007, 03:41 PM   #8 (permalink)
Quote:
The rears gave a little too much rake for my taste. The front was already tall enough with the 99 springs and we all know it is easier to change the rears than the fronts. So i put a set of 99 springs back in the rear and it is 1/2" lower than the front. This is the reason I am looking to make spacers. I am not sure off the top of my head what the 906's came to be, but I think it was 36.5" w/ 265 75 tires.
frodin - do the spacers you made cause the rear springs to squeak with them? I think I am gonna order my sheet of hdpe this weekend. I am glas you said 12x12, i was about to get a 24x24 just in case
__________________
'01 4Runner SR5 4x4
shiftMX is offline
Old 09-07-2007, 04:02 PM   #9 (permalink)
frodin1's Avatar
No squeeking at all. I was worried about them shifting around at first, but they sit pretty snug around the bumpstop so they haven't moved at all. I've got the Tundra/OME lift and it sat perfectly level, I just thought it looked a little bit better with a tiny bit of rake to it. An inch would have been to much for my application. This material has been used in the past by a lot of other members for the same purpose. That's where I got the idea and the place to get the HDPE. Good luck!
__________________
frodin1 is offline
Tags
10mm, 4runner, 906, coil, diff, diy, drop, emu, guide, homemade, kits, lift, man, rear, spacer, spacers, spring, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Daystar 2.5" rear coil spacers and 99' rear coils MATT0404 The Classifieds GraveYard 5 08-12-2007 06:51 AM
rear coils or coil spacers? Endeavor 86-95 Trucks & 4Runners 6 03-19-2007 12:26 PM
3rd Gen 4runner rear coil spacers JM The Classifieds GraveYard 1 12-05-2006 06:07 PM
2nd Gen. Upper ball joint spacers 1.5" and rear coil spacers 2" -MaTTi- 95.5-2004 Tacomas & 96-2002 4Runners 7 10-09-2004 11:21 AM
adjustable rear coil spacers swerks 95.5-2004 Tacomas & 96-2002 4Runners 2 09-20-2003 02:05 PM
2009 InternetBrands, Inc.
