Hitch....
Old 03-07-2004, 08:06 PM
Senior Member
data's Avatar
Hitch....
I'm in the market for a hitch. I have to tow a samuri this weekend. Is there anything special I should be on the lookout for or that I should purchase? Anyone have any recommendations?
Old 03-07-2004, 08:10 PM
96LtdYota's Avatar
I have a Reese Hitch and It tows everything great. I would look into Reese and see if it is in your budget. Mine has done very good work for me. Goodluck
Old 03-07-2004, 08:12 PM
Senior Member
data's Avatar
How much did it run ya?
Old 03-07-2004, 08:22 PM
Guest
4RUNR's Avatar
I looked out for an OEM on Ebay, found one for $50 for a used one. The OEM square tube design looks better than a tube on aftermarket, to me at least.
You can probably rent a hitch from Uhaul if it's needed for the weekend, then go on a quest for the long-term solution after that.
Old 03-07-2004, 08:32 PM
MTL_4runner's Avatar
There was just a thread about where to get them.
The tube one seems very popular.
Either of these are the cheapest so far:
http://www.hitchmart.com/
http://www.cheaphitches.com/store/catalog/default.php
Old 03-07-2004, 08:55 PM
96LtdYota's Avatar
mine is a Reese Class 3-5, 5000lb towing, part number R44048 and it cost me around $130. it took me 20 minutes to put it on and it works awesome. If the hitch is going to be temporary, rent one from uhaul. Good Luck Data
tirogers
16
11-02-2009 11:25 PM
MellamoPOUND
12-24-2005 12:41 PM
Quick Reply: Hitch....
