high swr reading - YotaTech Forums
Go Back   >
high swr reading
LinkBack Thread Tools Search this Thread
Old 04-21-2003, 05:46 PM   #1
doink's Avatar
high swr reading
hey guys
i got my rear bumper two days ago with my cb antenna mount on it. for some reason, when i put my cb antenna on the mount, the swr reading is unbelievably high. i tried to tune it, but nothing works..any suggestions?
doink is offline   Reply With Quote
Old 04-21-2003, 05:55 PM   #2
TDiddy's Avatar
How high is unbelievably high? Where exactly on the rear bumper is the mount?
Some people use a rear bumper mount with no trouble, but others (for whatever reason) aren't so lucky. If your antenna coax isn't all tucked away, the first thing I'd try is moving around to other locations on the rig. If you get better SWR readings, then at least you know you have other options.
You may want to look at the Firestik web site for more info on tuning and mounts.
TDiddy is offline   Reply With Quote
Old 04-21-2003, 06:05 PM   #3
doink's Avatar
the reading is basically at 3 all the way around. i dont have any pictures, but, where the tire mounts to the tire swing...behind the tire.
this is hawkdog's rear bumper, but, basically the same set up.
before i got my rear bumper, i had my 4 ft antenna on my roof rack and it worked fine.go here to see what it looks like
Old 04-21-2003, 06:21 PM   #4
Co-Founder/Administrator
Staff
Corey's Avatar
Your ground wire coming out of the antenna coax sheath, is it grounded right on the mount, or run a ways away?
Also make sure that the main antenna lead is not accidentaly grounding to the rig.
Make sure you have the two rubber/plastic gaskets as seen here.
http://pnw4runners.net/tando/qd2.jpg
You can't see the bottom one, but it keeps your main antenna lead from grounding to the rig.
Here is my ground wire.
http://pnw4runners.net/tando/qd3.jpg
I could have drilled right through the clamp and into the round ARB bar, but I choose not to.
A high SWR reading like that suggests an improper ground.
Corey is offline   Reply With Quote
Old 04-21-2003, 06:21 PM   #5
Sponsoring Member
midiwall's Avatar
This is a key statement. What's happening is that a lot of the output power is being reflected off the back of your rig. The roof rack worked well because there was nothing for the signal to bounce off of.
It looks like the firestik site has some good words. I hope you can find something that works for you. Any kind of distance you can get between the antenna and the rig will help.
If you still have the roof rack, that would actually be an ideal spot.
EDIT: Listen to Corey... I didn't even think about the ground issue. duh.
Good luck!
Mark
midiwall is offline   Reply With Quote
Old 04-21-2003, 07:20 PM   #6
Flygtenstein's Avatar
Nothing to add, just curious to read as my CB should be coming in a week or so.
I tried to look at those pics and they didn't work on my end Corey, maybe problems on my end?
Flygtenstein is offline   Reply With Quote
Old 04-21-2003, 07:23 PM   #7
doink's Avatar
i can not find any so called ground wires comming out of my antennas..one of them is a 3ft firestik, i forgot what type the other is though.. oh, corey, i couldnt get the first link to work..
Old 04-21-2003, 07:34 PM   #8
Staff
Corey's Avatar
Quote:
Looks like my site is down, and also my host
www.featureprice.com
When they go down, it all goes down.
They might be doing an upgrade on their end right now, so all their servers are off line.
Old 04-21-2003, 08:53 PM   #9
Sponsoring Member
midiwall's Avatar
Hi ya;
Actually, it looks like there are a couple of problems...
Both pnw4runners.net and featureprice.com seem to have fallen out of DNS - that's producing the "can't resolve" errors that some folks are getting.
My local DNS happens to have a cached address for featureprice.com (64.38.96.100) and tracing against that stalls out after just 4 hops, just as it's leaving Genuity (GTE) and heading for the backbone on it's way to Florida where your ISP is.
In short... I don't think it's them specifically; it's something else along the way.
Old 04-21-2003, 09:21 PM   #10
Staff
Corey's Avatar
Hmmmm, about 10 minutes ago I tried pinging them at http://network-tools.com/ and it would not conenct.
Perhaps a 'gator from the Everglades took a big chomp out of the cable that runs into their server shack
So this means it culd effect serveral sites that mya be on the same DNS?
A Quake III server I use is also with Feature Price, and they are down.
http://www.dayentech.net/
Old 04-21-2003, 09:33 PM   #11
Sponsoring Member
midiwall's Avatar
Hmmm... Thier IP address resolves out to an AT&T subsidiary up in Toronto. But at the moment, I can get to them without any trouble.
Yeup, they've fallen out of DNS as well.
Definitely... Anything on the other side of the common failure point would be affected.
Unfortunately, the Internet isn't setup like the long distance phone network. When a route goes down, there's no real provision to automatically re-route around the failure.
There's a red light and a pager going off somewhere. Depending on just what's up, it'll be back "soon".
Old 04-21-2003, 10:22 PM   #12
doink,
There won't be a ground wire on the antenna itself. The antenna is just an "extension" of the center conductor of the coax from your radio and is insulated from the mounting point by the plastic washers that Corey (I think) referred to. If you disconnect the coax from the radio, you could check the DC resistance between the center conductor of the coax connector to ground to see if there is low resistance which would be bad.
The outer shield of the coax is usually connected to the mounting bracket which should be well-grounded to the vehicle. You want that ground path to be as short as possible, ideally to a nice big horizontal metal surface with your antenna sticking up in the center above that. Your ground path looks like it is through the framework of the tire carrier, the carrier "hinge" or pivot, then the bumper, to the frame, and though some path to the body (not sure what gen you have, but I assume it is metal back there) that forms your ground plane. That makes a long path with quite a few places where the ground might be poor. Make sure you've got metal-metal contact for the coax shield first. If you check the resistance of the outside of the coax connector to ground with it disconnected from the radio it should be low. I wish I could give a precise definition of what is acceptable for "low". but I don't know. I'm mainly suggesting looking for gross errors like shorts or open circuits.
Even if you get a good DC ground, that doesn't mean you've got a good RF ground either, although other people have had success with this installation. You might experiment with a short wire from the tire carrier directly to the body to see if that changes anything.
I took a class many years ago from a guy who designed RF circuits. He used to say "Ground is not ground until proven otherwise."
Lots of strange things go on with radio frequencies, so it could be something besides the ground too as others have suggested.
From what I've read, and as has already been mentioned, mounting your antenna back there is never going to be ideal. If there isn't much antenna above the vehicle body, at the very least its going to distort the antenna pattern so you won't transmit or receive equally far in all directions.
alanh is offline   Reply With Quote
Old 04-21-2003, 10:45 PM   #13
Tacoma Dude's Avatar
Sorry to hear you're having problems...
My CB is still sitting next to my desk. Still haven't figured out exactly where I want to mount it...
Tacoma Dude is offline   Reply With Quote
Old 04-22-2003, 09:18 AM   #14
Staff
Corey's Avatar
I hope this can explain it.
Just made this page.
http://www.pnw4runners.net/tando/cb_coax.htm
This is how mine is done, and shows you what must be isolated as to not get a ground to short condition.
Old 04-22-2003, 03:13 PM   #15
doink's Avatar
ahh, thats a killer info site man. thanks a lot. one question though, i dont see a ground wire comin from my firestik...is it inside somewhere?
Old 04-22-2003, 03:22 PM   #16
TDiddy's Avatar
There's not a ground wire on the antenna itself; I believe Corey was grounding the coax antenna wire on that page. All the antenna does is screw in to the top of the mount.
What coax are you using? When I installed mine, I purchased a Firestik "Mini Kit", which had a ring connector already on the mount-end of the coax. All I had to do was throw it on the mount.
If you areen't using a Firestik mini kit, then you'll have to open up the coax and connect it like Corey has.
Old 04-22-2003, 03:49 PM   #17
doink's Avatar
nah, id ont have the mini kit. i have a coax cable i bought from radio shack. so from reading this, i have to cut into the coax cable or something? gahh, this is so confusing..i might just throw it back on my roof again, although, it did tend to be higher than some buildings..
Old 04-22-2003, 03:59 PM   #18
Staff
Corey's Avatar
Doink, should be two wires coming out of a sheath.
One wire is the ground, one is the one you put a connector on that goes under the bolt as seen in my picture.
That is the wire that must not touch any metal on your rig, and goes between the washer and bolt.
Worst case scenario, a CB shop will only charge you $20 to hook it up for you and do your SWR.
Old 04-22-2003, 04:11 PM   #19
TDiddy's Avatar
Doink,
No worries! Take a look at this pic:
All you need to do is open the end of the coax to expose the individual wires and throw some connectors on the coax as shown. The ring connector need to be isolated from the rest of the mount by using plastic washers. The ground wire just goes to the frame or good metal. Don't run it far though; it should only be a short distance from the mount, according to Firestik.
But yeah like Corey said, the worst thing is a few bucks for someone else to do it. That's not a bad idea at all, because they will do the tuning for you too.
Old 04-22-2003, 04:16 PM   #20
Thanks for the pics and such.
Has anyone tried the new Firering deal from Firestik? Looked pretty idiot proof, which is a good deal for me.
20R Break in- Really High Oil Pressure calderp Engine Swaps 2 08-16-2016 06:15 PM
Turbocharging A Stock 22re? RatOmeter 86-95 Trucks & 4Runners 15 10-22-2015 04:17 PM
HiGH oil pressure breaking in 20R calderp Pre 84 Trucks 8 07-27-2015 10:58 AM
96 3.4, very high idle no vacuum leaks I can find greenbuggy 3.4 Swaps 4 07-23-2015 12:51 PM
Looking for help with high RPM redghost.308 California SoCal 0 07-16-2015 08:46 AM
Tags
bumper, cb, cruiser, fj, good, high, ideal, mini, mount, reading, readings, red, swr, toyota, truck, wsr
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
