High mileage oil? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-02-2004, 08:03 AM   #1 (permalink)
High mileage oil?
Does high mileage oil make a difference? I have 87,000 miles on my 98 and I've seen some high mileage oil on the market that says for vehicles over 75,000 miles. Would it be beneficial to use that oil? And once you use that oil, is it one of those things that you have to continue using (ex. would it hurt the engine to switch back to regular dino oil)? Thanks.
havic is offline
Old 07-02-2004, 08:58 AM   #2 (permalink)
Highland Runner's Avatar
75,000 is high for American made vehicles, but not a Toyota. Every Toyota I've bought has had over 100,000 miles. 87,000 is nothing. Check out
http://theoildrop.server101.com/cgi/ultimatebb.cgi?
for info on oil. I think the high mileage stuff has conditioners to make seals soft again. You can change oils any time you want including going back and forth from dino/synthetic.
__________________
Chris
Mine-94 SR5 4-Runner, 3.0, 4X4, Aisin Hubs, Yakima Load Warrior, 210k Miles | Wifes-99 Limited
Highland Runner is offline
Old 07-02-2004, 09:11 AM   #3 (permalink)
4RunnerFever's Avatar
Send a message via AIM to 4RunnerFever Send a message via Yahoo to 4RunnerFever
I'd suggest synthetic. Either Mobil 1 or Amsoil. This should prolong the life of your motor indefinitely.
Highland Runner - you should get a website Nice Truck!
__________________
2004 Tacoma Double Cab, TRD Off-Road, PIAA fogs, ARE Shell, Yakima, etc. 4RunnerFever
_______
GBNF: 1998-3rd Gen-4Runner, SR5, 4WD, TRD Supercharger, TRD Cat-Back, 3-inch Revtek Suspension Lift, 285/75-16 Revos, 4Crawler Offroad 1" body lift, Sonoran Trac Bar, Hayden Cooler, Hood Scoop, 'Outback' Mod, Optima 34R, Amsoil, Yakima, PIAA, etc. Sold to Mastacox.
4RunnerFever is offline
Old 07-02-2004, 11:32 AM   #4 (permalink)
Thanks 4RunnerFever. And I second the two oils you mentioned. I started running M1 about 15,000 miles ago, because my mileage is getting high. Runs great.
4RunnerFever- your Runner is very nice also. I'm always impressed by the number of well built trucks/SUV's in Boone/Banner Elk area. Must be a necessity with winter and road conditions.
__________________
Chris
Old 07-02-2004, 02:02 PM   #5 (permalink)
mike_d's Avatar
no, don't use it. it's not a good idea. i'm at work now, so i don't want to take the time to search in the newsgroups for the posts, but basically the high-milage oil has some stuff in it that helps the seals swell to stop leaks and some other stuff. basically it's good for short term fixes on old engines. but it is no good for the long term. i remember briggs and stratton did some in house tests and found that initially the high-milage oils, and oils with additives like teflon did very well, but in the long term they found significant scoring and wear on the pistons and bearings.
i'm a believer in synthetic oil, particularly mobil 1, but i bet any good synthetic will do. as a chemist, i've read a bunch about synthetics and they are significantly better than mineral oils. and for me cost isn't an issue because i put the new oil in my new car and use the oil from my new car in my old trucks, and even after 6000+ miles and 2 vehicles the oil comes out mostly clear.
__________________
mike
'89 4Runner DLX: 2" OME rear springs, 1 5/8" RB BJ spacers, Diff Drop, 32" MT/R.
'90 4Runner SR5: Stock Suspension, 32" MT/R .
'07 4Runner SR5: 2" OME Rear Springs, Donahoe Coil Overs, Total Chaos UCA, 275/70-17 MT/R.
'76 Jeep CJ-5: 4" Lift, 33" BFG MT.
'87 Saab 900S: All stock
'99 Subaru Legacy GT: All stock
mike_d is offline
Old 07-02-2004, 10:06 PM   #6 (permalink)
jimbo74's Avatar
Send a message via AIM to jimbo74
i dont know about the testing of damage... however, all the high mileage oils are are oil with more detergents/cleaners for older engines.....
the shouldnt increase/reduce wear, however, they will help keep rubber seals softer allowing less oil leak if you already have one....
if you change the oil at regular intervals, you dont need high mileage oils..... either dino or syn
jimbo74 is offline
Old 07-02-2004, 10:15 PM   #7 (permalink)
bike4miles's Avatar
Send a message via Yahoo to bike4miles
I used castrol high milage in my 4runner (165,000 miles) and it actually increased my oil presure! I'm not kiding. Seriously. It cost like $5 a quart but I plan on using it again next time.
__________________
--Miles
Sold
'91 4runner, 22re, 5 spd manual, 180,000 miles,
cone filter, Downey 1.5"HD coils, SkyJacker Nitrogens, Magnaflow Exhaust, Stull grill, Clears all around. Check out my sound proofing project and other mods:
My 4runner page
My 2006 Camry page
I'm a Myspace Addict!
bike4miles is offline
Old 07-03-2004, 07:17 AM   #8 (permalink)
mike_d's Avatar
Quote:
actually, the rasising of the oil pressure might not be a good thing. from what i remember about the briggs and stratton test was that extra stuff in the oil will block the smaller channels that the oil goes into and cause extra wear because of oil starvation. that may be what's happening in your truck, if the pressure is high, that could be because the oil isn't getting through to all the places it should. i'll see if i can find that test i'm talking about so that people don't need to take my word for it.
__________________
mike
mike_d is offline
Old 07-03-2004, 07:24 AM   #9 (permalink)
mike_d's Avatar
here's what i was able to find.
http://www.vtr.org/maintain/oil-additives.html
i'm sorry, i couldn't find the other document i was thinking of, but this one is not bad.
__________________
mike
mike_d is offline
Old 07-03-2004, 09:56 AM   #10 (permalink)
This may have been true about American Vehicles in the 80's and is still true about some. But I'd suggest you evaluate the Wards Top 10 Engine list and JD Powers reliability ratings.
Basically, you get what you pay for.
radrex is offline
Old 07-03-2004, 03:11 PM   #11 (permalink)
jethro's Avatar
Quote:
Welcome to Yotatech. Looks like we were a little more help.
http://www.automotiveforums.com/vbul...d.php?t=251467
__________________
2002 4runner
jethro is offline
Old 07-05-2004, 05:40 AM   #12 (permalink)
Cut and pasted directly from the JD Power site.
Listed as below average in long-term dependability are, in alphabetical order: Chevrolet, Chrysler, Dodge, Eagle, GMC, Hyundai, Isuzu, Jeep, Kia, Land Rover, Mazda, Mitsubishi, Plymouth, Pontiac, Suzuki, Volvo and Volkswagen. Power does not publicly release the below-average rankings.
But Power does name the top vehicles in each category, and here Toyota holds an impressive six first-place spots with its Tacoma, T100, 4Runner and Supra models. Lexus garners two spots with its LS 400 and LX 450, and Honda holds two top spots with its CR-V and Civic.
Source: J.D. Power and Associates 2001 Vehicle Dependability Study
Looks like it's still true.
__________________
Chris
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
when is the mileage too high for you to buy? The_Big_D 95.5-2004 Tacomas & 96-2002 4Runners 17 09-06-2006 07:17 PM
High Mileage? Mattism78 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 4 09-28-2005 06:59 AM
synthetic oil + high mileage = lesson learned. ChickenLover 95.5-2004 Tacomas & 96-2002 4Runners 30 08-03-2004 07:36 PM
Best oil for high mileage red 59 95.5-2004 Tacomas & 96-2002 4Runners 18 06-02-2004 04:47 AM
Regular Maintenence and high mileage oil DuB Maintenance & Repair Archives 5 04-13-2003 01:12 PM
2009 InternetBrands, Inc.
