HID kits on ebay and in general
okay so iv got some money and after comming home for thanksgiving and back i want hids. the local 4x4 shop in missoula has some that they will sell, instal, and aim correctly as to not blind others for around 500-600 bucks maby more. then on ebay they have kits going for around 175-365 and it would be about 200 bucks for instalation. these kits come with osram or hella balasts. which do you guys think i should get? price is a huge issue otherwise id get a set from an sc430 or a catz system and get custom projectors mounted in my existing headlamps by that company.
thanks
thanks
thanks
thanks
do you mean you're going to get the projectors? best kits that are out there are philiphs Ultinon Xenon kit and also Katz. Those run around $500 alone, You'll also need projectors which are usually around $100-$150 on ebay(Audi, BMW are most popular and best ones) that's without retrofitting labor. someone on this board has also done this. Run a search and you'll find out more. He used aluminum foils to make his shroud. If you want one without projectors, you can get a shield kit to aim correctly for around $60 if i remember correctly. If you go without projectoros, install would be very easy for DIY.
Originally Posted by Bratik
You should save some money and do it once correctly, meaning: getting projectors that were design for Xenon/HID bulbs, this is the only way to get great visibility without blinding other people. Check out HID Planet for a lot of information on HID. I just completed retrofitting Infinity FX projectors into my 2000 headlights. Good luck!
just buy the billet HID shields from casper electronics like i did, as long as you have an H4 it'll work. the D2S or D2R HID bulb just fits right in and you can aim your own headlights. i have them and there are no problems at all with beam pattern.
https://www.casperselectronics.com/M...Category_Code=
Originally Posted by 2001Millrunner
so you can buy like an OEM hids(Lexus, Audi, Acura) and use this adapter to fit it in plug-and-play?
Gene.
Originally Posted by 4runner4me
How much would you do mine for? Your truck looks great! How did ou get the front lens off and get it sealed again?
I'll take pics sometime this week of my projector beam pattern. I do however have pics of the Casper shields as kawaii005 said. Beam pattern is just like normal stock lights, just more intense.
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
01-16-2016 06:38 PM
jerusry
10-19-2015 05:28 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
Peevedkitten
11
08-31-2015 06:57 PM
