Hi lift owner's, quick question
I know sliders are the best jack points and they are coming...eventually. But, is the factory tow hitch a safe place to use as a jacking point?
Yep, the tow hitch is a fine place to jack from. That's about the *only* safe place on a stock rig unless you get one of the specialized gizmos for lifting from the wheel.
A bottle jack at the rear axle or the crossmember up front would be a lot safer and more reliable.
Why use a Hi-Jack on a stocker? They are trail tools, not shop reliables.
Location: White Mountains, Arizona (Yes it does snow in AZ)
I agree w/ Flygenstein.... trail only tool. I usually carry a 2x4 about 2" long and jack it up on the body pinch weld. I hate highlifts and will avoid using it any time I can unless it's absolutely the best tool for the job. I have winched myself out, lifted up the front/back end to stack rocks and even used it to move downed trees in the trail. They are useful but dangerous and should be treated w/ a great amount of respect.
Originally Posted by mt_goat
Safe for the truck maybe, but not safe for anyone standing around at the time. If you jack from the tow hitch, as soon as you get both rear wheels off the ground the jack will tip over. Ask me how I know
Hmmm. Fun with physics... If you have a 4' hilift up about 2 feet when it tips, and say around 2,000 lbs on it, the free end of it will hit any interceding object on its way down with a force of 1,000 lbs. Pretty much the same as if you dropped a pallet of bricks on your head.
Ok, I'm convinced it's dangerous... how 'bout you?
What are the dangers involved in using a hi-lift...except having the truck slamming down? if it does fall off the lift, does the jack just fall down or does it become a projectile? I'm only using it as a recovery device. Since I don't have sliders yet, I would be getting the wheel hooks that hi-lift makes for the jack.
It doesn't become a projectile, but the falling truck itself is a frightening beast, because it isn't dropping straight down usually, it tipping off the jack, so anyone "downwind" of it is in jeapordy.
Also, the handle of the jack is whipping around at a really good clip, and could flat take someone out. And if you happened to be under the truck building up a rock ramp or similiar chores, curtains-time...
You're dealing with thousands of pounds here, which is what makes it scary.
I'm not an expert on this... I just like physics!
(Random meandering ahead...)
I think we (YT) should make a hilift safety video with some "don'ts" where we explode watermelons or the like with the pieces of flailing metal that occur in a hilift screwup. Any volunteers?
Mebbe jack up a truck by the tow hitch on flat and level, unblocked, and show how little force it would take to tip it?
Edit: Thanks for making me think about this! I'd rather work this stuff out before I need it sometime!
So, has anyone actually had any bad experiences with the hi-lift? IF the truck does tip off the jack, how does the jack usually fall? Would it slam against the body...resulting in major damage?(of the truck...not you)
jasonty
41
12-23-2018 01:00 PM
rushw
07-18-2015 01:46 PM
icentropy
07-14-2015 10:23 AM
