hey guys
hey guys
hmm..i just finished checking out the Gear Page and i have G294 which is a 8.0" gear with 4.10 ratio and a 4 Pinion, Open Diff. so then i was checking at the bottom where it said that 4.10 ratio should be used with 225/70R-15 tires, but i have 31's on. so i was wondering if this would affect my speedo and gas milage? something effects my speedo b/c when i drive my moms car to school its 110 miles there and back, and when i drive the 4R its only 100. thanks guys.
Huh?
I might be missing something here, but I don't think the axle gearing has anything to do with the speedo inaccuracies. The speedo gear/adjustment is for the diameter of the tires.
Cebby, the Axle Ratio has everything to do with Speedo/Odometer inaccuracies. Actually, it's a matter of the Final Drive Ratio including tire diameters. But below is a simple explanation of why it matters.
If the Axle is making more (or less) turns per mile than when it left the factory, then the Driveshaft and subsequently the Transmission is making more turns per mile and therefore the Speedometer Gear and/or the VSS (Vehicle Speed Sensor) is sending the wrong information to the Odo/Speedo.
The leg bone's connected to the knee bone, the knee bone's connected to the thigh bone, the thigh bone's connected to the hip bone, etc. etc. etc.
Hope this helps.
Dr. Z
Hope this helps.
Dr. Z
I guess I never understood it that way. So, you are saying that if I have two identical vehicles with the same size tires and same speedo gear, that have different axle gearing, that I will get different speeds at the speedo?:confused:
Hope this helps.
Dr. Z
The spedometer connects to the transmition so any changes to diff ratios or tire size throw the spedo and odometer off unless you do the math and get the right combination.
so then i see where the 10% thing comes into effect with the 100/110 mile thing. hmm..so when im on the highway going 80 mph..im really going 88...now wonder i fly by everyone. so then if i have to fill up every 150 miles...the odo should really say 165?
pyramid
07-30-2015 10:05 AM
scottyg486
07-19-2015 05:34 PM
Iceman4193
07-15-2015 04:48 PM
