YotaTech Forums
YotaTech Forums (/)
-   95.5-2004 Tacomas & 96-2002 4Runners (http://www.yotatech.com/f2/)
-   -   Helper Spring install ?'s... (http://www.yotatech.com/f2/helper-spring-install-s-58742/)
brendonv 05-09-2005 03:20 PM
3 Attachment(s)
i got this set of trail master helper springs from my buddy...where do they go? choose a, b, c, or d...and do you think ill need to get some new u- bolts??
ARB4STUNNA 05-09-2005 03:37 PM
I believe they go at the bottom of the leaf pack, so A would be my choice. But I might add I have seen some that go on top too, so Im not 100% sure. Did you see how they were installed on your friends truck? Check the length of your current u-bolts and see if they are long enough to accommodate the helper leafs. I would think you probably need some longer u-bolts.
brendonv 05-09-2005 03:47 PM
thanks, he actually never had em on the truck so im not sure
Steveh29 05-09-2005 03:53 PM
Yeah. They go on the bottom of the leaf pack - so A. Be sure to check the U bolts a couple of times after driving around to make sure they're tight.
brendonv 05-09-2005 04:16 PM
how much threads should be beyond the nuts on the u-bolts? the addaleaf is exactly the same width of the threads that are left on the ubolt from the stocks...
4Crawler 05-09-2005 05:38 PM
Usually you want the AAL between the stock overload leaf and the rest of the leaves, or in place of the stock overload leaf. Reason being that the stock overload leaf is very thick and very stiff and very flat. Put the AAL under it and the two leaves fight each other, the thicker/stiffer one wins. Ideally you want at least one thread beyond the nut on the u-bolts.
brendonv 05-09-2005 06:10 PM
so ur saying to put it in position B?
superjoe83 05-09-2005 06:12 PM
Quote:
so "B" is the proper location
edit: to late, yes b is the right spot
4Crawler 05-09-2005 06:17 PM
Yes, the big thick leaf on the bottom is the overload leaf. It generally will not bend, that is it's whole purpose in life, to keep the rest of the springs fropm bending backwards too far if you overload the truck too much. I have some tips on installing add-a-leaves on my web page:
http://www.4crawler.com/Diesel/Cheap...l#Add-a-leaves
jimbo74 05-09-2005 06:18 PM
1 Attachment(s)
B is where you want it as roger said.....
brendonv 05-09-2005 06:26 PM
thanks guys
2010 InternetBrands, Inc.
