YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 12-12-2008, 11:40 AM   #1 (permalink)
Personal Sales Rating: (0)
mtnmuse's Avatar
Help...where to connect OBD-II code reader
The check engine light glowing bright on my 2000 4Runner. Of course the dealer wants $125 to read the code, so I'd like to trouble shoot the issue at home.
Bought a "Creader", which was recommend on Yotatech, for generic OBD-II vehilcles to read the error code(s). Packaging states for "use on all models since 1996 with a 16-pin diagnostic socket". Tryed to plug it into the Toyota "Diagnosis" plug in the engine compartment, located above the drivers side spark plugs, but the plug types are different and will not connect.
Is there a different place to attach the code reader?
Did I just buy the wrong code reader?
Do you have a recommendation for a replacement code reader?
Thank you for any insight and input offered.
__________________
2000 4Runner SR5 Sport
ARB lockers * 4.88's * OAR Manual Hub Kit
ARB Sahara bar * Demello rear bumper & sliders * Warn XD 9.5
Camburg coilovers & A-arm, OME 891/N86
Sonoran Steel diff drop, e-brake & panhard drop brackets
Iraggi 280 amp alt * Optima 34R * 6 KC Ti SlimLites
AOR brakelines * Wilderness Sport Rack
Deck plate mod * Amsoil airfilter
Alpine CDR-9833, Image Dynamics CXS6, IDQ10
Cobra 18WX & 4' Wilson
mtnmuse is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 12-12-2008, 11:45 AM   #2 (permalink)
Vendor Sales Rating: (0)
The spot that you plug it into should be under the dash. All obd 2 plugs are the same so yes you did get the right one.
eatmorechicken is offline
Old 12-12-2008, 11:57 AM   #3 (permalink)
TRT4Runner's Avatar
Under the dash directly above the gas pedal....
__________________
TR
'99 SR5 auto
TRT4Runner is offline
Old 12-12-2008, 12:09 PM   #4 (permalink)
Threadstarter [OP]
mtnmuse's Avatar
found it thanks.....code 0171...."system to lean"
now how to fix that???
Thank you for your help
__________________
mtnmuse is offline
Old 12-12-2008, 12:37 PM   #5 (permalink)
Time to clean your MAF..... might as well,clean your throttle body and IAC valve(short cut way)...If you take the intake boot off anyway..
Lots of info about both...do a search
97ltd4x4 is offline
Old 12-13-2008, 12:04 PM   #6 (permalink)
florider's Avatar
look at the 1999 4runner thread. 97ltd does a real nice write up there on the iac valve
florider is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
0171, 1999, 2002, 4runner, 99, code, ii, location, obd, obd2, obdii, plug, tacoma, toyota, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
94m 4 Runner OBD II code reader needed Dave Mooney 95.5-2004 Tacomas & 96-2002 4Runners 5 01-09-2010 01:31 PM
Code Reader Laser_Guy_1984 General Electrical & Lighting Related Topics 3 06-28-2007 03:54 PM
CReader OBD II diagnostics code reader Tacoma Dude 95.5-2004 Tacomas & 96-2002 4Runners 18 03-07-2004 05:25 AM
Best OBD II Reader out there! MTL_4runner 95.5-2004 Tacomas & 96-2002 4Runners 16 01-09-2004 09:28 PM
throttle position using OBD reader/BR-3? 3.4Runner 95.5-2004 Tacomas & 96-2002 4Runners 2 12-29-2003 06:22 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
