Help w/ maintenance for 3rd gen (98k miles)
Old 10-11-2005, 08:48 PM
ebelen1's Avatar
1. Thanks Bob for the link to Toyota service intervals and required service.
2. I have a 3rd gen w/ 98k miles and the timing belt was done at 60k. Other than this, basic oil changes, battery replacement, shock replacement and new tires are all that's been done on this truck for maintenance purposes.
3. I will be out of the country for two weeks and I have a laundry list of items I want done to my truck as follows:
4. BG Cleaner (similar to Seafoam) in the engine and gas tank. I'd like to do this to get any crud out of the motor and gas tank, if applicable. First question is will this require new plugs? Others that have used Seafoam have talked about having to replace plugs due to the cleaning.
5. Tranny flush w/ Amsoil tranny fluid. Will also add a Hayden tranny cooler. My mechanic has driven the car and he says that the auto tranny shifts fine so no issues with doing the flush as others have claimed that a flush should not be done after 50k miles if this was not regularly done. Any thoughts?
6. Fuel filter - very basic.
7. Adjust rear drums and e-brake. New steel-braided lines up front for the Tundra brake conversion (recently done). Bleed brakes.
8. Change rear diff fluid to synthetic.
9. Clean throttle body and FIPK (no MAF I think)
10. Radiator flush.
For a major, there are a few extra items that I did not include such as plugs, which were changed 5k miles ago and an oil change that was recently done. Maybe after the engine cleaner, I will need new ones. I'm also waiting on new spark plug wires.
Did I miss anything? I would hate to have a bunch of items done and miss something b/c I want this to be the last full service for awhile. FYI, I drive less than 10k miles a year.
Old 10-11-2005, 08:55 PM
kevin444's Avatar
the belts, water pump, timing belt.
Old 10-13-2005, 04:48 AM
MTL_4runner's Avatar
BG44 is good stuff too, I used to use that when I was a mechanic and it worked quite well.
I disagree with that....unless the tranny fluid was burnt I am of the opinion it is fine to do a tranny flush at almost any time in its life. When the fluid it burnt, I'd just change the fluid in the pan multiple times to buy time before a rebuild.
I would if not done for a while.
Not sure if you are in a rust belt but check to make sure all the e-brake parts move freely up to the rear drums (one of the levers which attaches to the drum assembly has frozen up on mine and it makes it impossible to adjust the rears properly). Just pull on the cable at the back of each drum and make sure it moves.
Synthetic may help MPG a bit.
Will help idle to clean the TB. Yes, you do have a MAF and I might consider cleaning it if you do have a FIPK.
10. Radiator flush.
Use Toyota red or another long life coolant (prestone makes a long life too that I use).....no green stuff.
You may need new plugs or you may not. Depends how much stuff gets dislodged during the cleaning. Just pull a plug after and have a look. Replace if they look bad.
Pretty good list IMHO.
See responses in red above.
Old 10-13-2005, 06:17 AM
ebelen1's Avatar
MTL 4 runner, you're awesome. I'll print out your responses and give the sheet to the mechanic.
Old 10-15-2005, 04:58 AM
Lance's Avatar
What about lubing the driveshafts?
Old 10-15-2005, 04:07 PM
ebelen1's Avatar
2WD, no lubing for me. Thanks though.
Old 10-15-2005, 04:33 PM
msw0085's Avatar
mm you still should keep your main driveshaft lubed... if youve ever been sitting at a red light and felt a slight jolt forward, it is past due (assumes auto tranny)
Old 10-17-2005, 05:11 AM
2wd are non-serviceable.....only 4wd have the zerk fittings.
On a 4x4 that should be part of regular maintenance (at least once a year).
Old 10-17-2005, 06:41 PM
dallison's Avatar
is this something that be done by me, and if so what equipment do i need??
we had the dealer do it @ 75k but it's still doing it, they said it was starting to get dry
Old 10-17-2005, 08:32 PM
msw0085's Avatar
idk i would defer to MTL_4runner on this one..he def knows what hes talking about..I know my old 2wd occasionally had the situation I described..search around some if you havent..
Old 10-18-2005, 12:59 PM
What vehicle is this?
4x4?
smthwsn357
12-04-2023 02:08 AM
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
jerusry
10-19-2015 05:28 PM
tpd143
07-07-2015 09:06 AM
Quick Reply: Help w/ maintenance for 3rd gen (98k miles)
