Help with TSB's...
Old 08-30-2004, 07:33 AM
Help with TSB's...
Is there a site for TSB's? I recall a TSB that I never acted on. I have a '96 Runner that buzzes when I turn it off, the buzzing continues intermittently for days!
Thanks,
Emil
Old 08-30-2004, 07:42 AM
waskillywabbit's Avatar
Talking
http://www.alldata.com/
Search by make, model and year.
Old 08-30-2004, 08:06 AM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
also:
http://www-odi.nhtsa.dot.gov/cars/problems/tsb/
Old 08-30-2004, 08:09 AM
BajaRunner's Avatar
I have that exact same problem.
Mine comes from the drivers side, near the fuse box and master cylinder.
Old 08-30-2004, 08:41 AM
bradym239's Avatar
Okay, so I am TOTALLY uninformed. If I found two (relating to the same problem) TSBs for my truck. What do these mean for me? How do I use them to get the problem fixed? Any and all help is greatly appreciated.
Regards,
Brady
Old 08-30-2004, 11:01 AM
User 051420's Avatar
If you need specific TSB details I can get them for my 97 runner. I'm a member @ alldata.
Old 08-30-2004, 12:20 PM
Hey, that would be great, I think the number is EG00297. That should be for the buzzing Evap Canister. Will that show me how to fix it or do I need to go through the dealer?
THANKS AGAIN!!!
Emil
Old 08-30-2004, 12:29 PM
rimpainter.com's Avatar
The buzzing is caused by the EVAP canister. If you put your ear by the canister, you can narrow it down to a line that plugs into a big round looking thing attached to an even bigger box (the canister). If you pull that line, which comes from the fuel tank, it will stop the buzzing; however, it will also release fuel vapors (you will smell it, trust me) into the engine compartment, which is not good.
Your best bet is to get the upgraded part from the dealer. Personally, I don't care about the buzzing so I just let it go.
Old 08-30-2004, 01:35 PM
Emil: Here's the page from Alldata.com. If it doesn't work for some reason I'll PM you my username & password and you can have at it!
Clicky
Old 08-30-2004, 02:07 PM
Perfect. Thanks very much!
Old 08-30-2004, 03:19 PM
BTW Emil: Where do you go wheelin in Casper? Riverton seems to be pretty well consumed by private land.
EDIT: Wanna race sometime?
Old 08-31-2004, 06:07 AM
I don't want to race you, you have a cupholder mod!
I mostly stick to BLM lands, a few small areas around Casper.
Old 08-31-2004, 06:10 AM
You forgot about the TRD Stickers..........
jacked_72
09-14-2015 03:31 PM
1996Taco
07-20-2015 12:02 AM
The Dutch Man
05-17-2004 12:48 PM
bobzemuda
11
12-22-2003 10:32 PM
Quick Reply: Help with TSB's...
