Help with top plate extended studs
Old 06-09-2010, 03:48 PM
snoozer's Avatar
I'm finally getting around to installing my OME 90004s and tundra coils to replace my 2" cornfed spacers and stock shocks.
Any tricks to getting the extended studs into the top plate? Or do I just need a bigger hammer?
Old 06-09-2010, 04:21 PM
pfdaxe's Avatar
I put my top plate in a vise and gave it a quick tap with a hammer and they went in with no problem.
Old 06-09-2010, 04:51 PM
brian2sun's Avatar
Why do you need extended studs when you're loosing your spacers?
Old 06-09-2010, 05:17 PM
snoozer's Avatar
For the top out spacer. I've got the old bamachem style ones. The cornfeds use their own bolts since they act like a top plate. I've long since lost the nuts for the original toyota top plate studs, but I have the Revtek extended studs, nuts and all.
These studs are a fight going in, just like the originals were coming out.
Old 06-09-2010, 05:55 PM
brian2sun's Avatar
When I installed my old Daystar lift (which is long gone now), I put the top plates in a vice and smacked the studs out and smacked the new ones in with a small sledge. I don't remember it causing me any trouble.
jasonty
41
12-23-2018 01:00 PM
pyramid
07-30-2015 10:05 AM
4Runnin2000
07-29-2015 06:09 PM
TDonkey
07-26-2015 10:14 AM
CanRunner
07-20-2015 01:29 PM
Quick Reply: Help with top plate extended studs
